hello all, need a bit of help -![]()
before i reinstalled xp on my pc i was able to burn my 700mb movies 5 at a time on to my blank dvds e.g 4 or 5 movies on each dvd, all of my movies would be in my movies folder and each file would have the windows media file icon on it. i was able to burn with nero vision everything was great no problems.
but ever since i reinstalled windows, the burning process has not worked eg i copy 4 700mb files on to a dvd using nero vision the first file might work but usally the pc will freeze for a few mins. the only difference that i can see is that the movie folder that i use, the icons on the movie files is not the windows media icon but a film strip with AVI wrote in it. so iam thinking this is the problem.
the old dvds i have with films on them are still working so its not the dvd player on the pc. must be the file type but i cant seem to be able to fix this problem???
nero vision come up with a loads of these errors -
read errors from sector 841776 to 841839
read errors from sector 841776 to 841839 thes numbers should be different for each line, i just copyed and pasted them.
hopefully someone can help me....
robert!!
ps i have updated the plugins on nero
Results 1 to 10 of 10
When you play one of the files what does it open with?
He's a liar and a murderer, and I say that with all due respect. -
thanks for the responce, windows media player, but i have tryed loads of different players vlc, windows media classic, GOM player, they will play on the pc but wont play from the dvd when burned, when i try to open them from the dvd the pc will freeze for a few moments
I'm a bit confused now
You get the files from your pc onto a blank DVD but when you burn and play the films back your pc will freeze? Or you can't get the films to burn to a blank DVD?
yep pc will freeze when i play them back, the odd one will work eg the first film on the dvd might work but the other 3 on the dvd wont. and if you try to play them the pc will freeze. and when iam burning the dvds iam getting the errors
from nero vision... -
If you're getting read errors while burning, the problem is with your HDD - Nero can't read the source file.
Try copying the AVIs to some other location on another HDD (or in another folder) and try writing them to DVD.
/Mats -
ya have just tried moving to another HDD and also tried moving to another folder.
2 of the 3 films worked, but the 3rd did not.
i have noticed that when the burning is happening in nero vision the problem seems to start around 70% and continues till the 100% with all the "errors reading from sector 868533 to 869789" start to happen from 70% onwards, but the burning goes fine untill it gets to this stage. the burning really slowsssss down from 70% onwards... any ideas? -
anybody got any ideas or directions i should take??
anything at all, besides trowing my pc out the window...
IsoBuster settings for read errors
By 1337assassin in forum Newbie / General discussionsReplies: 8Last Post: 23rd Oct 2010, 12:20 -
How to Convert VOB file from DVD with ignore read errors
By designbuyers in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 09:17 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
Is it possible to overcome read errors in homemade DVD?
By geepondy in forum DVD RippingReplies: 8Last Post: 19th Jun 2007, 22:21 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
