    Nov 2006
    Canada
    Hi,
    I would appreciate your suggestions and help in finding an
    HD/DVD recorder that I will use to transfer about one hundred
    120-Min Hi8 video tapes on DL DVDs.
    I want to do this transfer with the highest possible quality.
    I am looking for the following characteristics:
    1. Ability to record on DL DVDs.
    (I want one DVD per 120-Min tape, and
    I would like to optimize the quality of the transfer).
    2. Ability to record in Flexible/Best Fit mode
    (The XP mode does not provide enough recording time
    on a DL disc: with XP I would get only about 115 minutes,
    but I need 120 or even 125 minutes,
    since 120-Min Hi8 tapes are actually a few minutes
    longer than 120 minutes).
    3. DV-input (for convenience: one-cable video/audio
    connection to my digital DV-camcorder)
    4. S-Video input (to connect my older Hi-8 analog camcorder.
    It is hard to believe, but some new recorders
    do NOT have an S-video input! For example, the new
    Liteon DD-A500GX has HDMI upconversion but no S-Video input
    5. HD (for convenience to record TV programs)
    and, if at all possible:
    6. LSI chipset (to optimize recording quality).
    Thanks for your help!
  2. There are very few DL recorders, that should narrow down your search quite a bit.
    (https://www.videohelp.com/dvdrecorders)
    Btw, have you considered that few dvd players play DL disks you write yourself?
    Nov 2006
    Canada
    Hi Handyguy,
    thanks for your suggestion. I tried the search function with just three of
    my 6 desirable features": DL recording, DV input and having a HD.
    (There is no option to search for "flexible/best fit recording".)
    This search narrowed it down to few DVD/HD recorder brands:
    - Hitachi (I have seen little, if any, info on these)
    - LG (but the one I know off does NOT have a "flexible/best fit" recording)
    - Liteon (a possibility, but I think it has flex recording only for "timer" recordings)
    - NEC (are they available in Canada? do they have flexible recording?)
    - Panasonic (a possibility, but I am concerned about the recording quality/macroblocks at lower recording settings)
    - Philips (reliability problems)
    - Sony (for some reason they do not seem very popular among the forum members, why?)
    I will have to check out the above list more carefully...
    By the way, I did not know that most DVD players do not play DL disks.
