Hi,
I'm sure there isn't a way, but I want to know if it's possible to convert a VHS motion picture that I own (but it copywrighted) onto a DVD? I own a dual VHS/DVD machine that dubs one onto the other. I own a few old movies on VHS and want to make them DVDs for my own use. Is this something that can be done?
Thanks in advance!
There is totally a way... that's what goes on here!
You machine dubs one to the other? So you mean the VHS can record the DVD? Or do you mean that the DVD can record the VHS? If the latter, then you are all set!
If the former, you need a machine that does the latter - check the DVD Recorders link on the left.
I use a capture card in my PC for this. Record to MPEG and burn to DVD.XP
Intel Celeron D 335 Prescott 2.8GHz Socket 478 Pro
600GB
2G
ATI Radeon X1600 Pro
GIGABYTE GA-8I848P-G Socket 478 Intel 848P ATX Int
Lite-On DVD SOHD-16P9S
Hauppauge WINTV-PVR-150 PCI Interface Tuner Card -
You will find that some VHS videos have copy protection on them and will not copy in your machine.
If you find a VHS video like that then you can copy it but not without buying into some special hardware.
So have you discovered one or more VHS videos that will not copy or is your question just a general question and you haven't actually tried yet?
I tried with one movie, but came across the copywrite. Do I just try for each movie or suck up and buy the software to copy it and not worry about the copywrite?
You need hardware not software. A TBC is one device but considering you could buy 10-15 DVD's for the same amount it's not very practical for your purposes. there are cheaper things that are supposed to work. Do a search for SIMA.
Dead Panasonic DMRES35V VHS/DVD Burner Combo
By Painasonic in forum Newbie / General discussionsReplies: 4Last Post: 4th Jun 2010, 15:26 -
vhs-dvd burner-imovie
By shard in forum Newbie / General discussionsReplies: 1Last Post: 23rd Apr 2010, 13:20 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
Tuner for Zenith XBR715 VHS/DVD(burner)
By solarblast in forum DVD & Blu-ray RecordersReplies: 3Last Post: 23rd Jun 2009, 12:03 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 21:15
