Results 1 to 11 of 11
  1. Member lumis's Avatar
    Jan 2005
    the remnants of pangea
    I contacted one of my local television stations asking them if they would switch from grey bars to black bars when broadcasting non-HD programming.. I received this response back.
    Thanks for writing!  We decided to use the grey bars instead of black to minimize burn-in on those sets (plasma, rear-projection, CRT, LCD) that are susceptible to it.  We started with black bars but received comments from viewers about the burn-in issue.
    Frankly, I find the grey bars a little distracting, too, but it's a small price to pay for no burn-in, at least in my opinion.  If you have one of the above-mentioned sets, I'm sure you'll appreciate it too in the long run.
    I'm not trying to argue the point or anything. I'm just curious if this information is correct.
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Yes, black bars can cause burn in.
    Google is your Friend
  3. Member lumis's Avatar
    Jan 2005
    Thanks for your response Krispy Kritter.
    If you would elaborate a bit, do black bars cause more burn in than grey bars? Or do grey bars not cause any burn in? Or do they cause the same amount of burn in?
  4. Pure black, no lite pixels
    Grey, lite pixels
    Burn-in in the case of black bars on the side, would show a brighter picture where the black bars were later on during HD or 16x9 viewing
    Originally Posted by jagabo
  5. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Think of it this way. The actual wear mechanics vary by screen technology.
    The 4x3 area in the center is what is being burned in from use. Over time the picture brightness fades from pixel use. Extensive 4x3 use would result over time in the center area appearing dimmer than the side area when watching 16x9 material. Gray side bars age the side areas equally minimizing the wear difference.
    Other types of burn-in result from unchanging high contrast still images (e.g. Windows desktop, menus or video games) left stationary on the screen for too long. From then on, a ghost like burn in is visible while watching normal video.
  6. BTW, I had this problem myself.
    I was watching SD channels for about 2 weeks in 4:3 mode (normal mode on my plasma) in stead of zooming in a little and chopping off the top and bottom to fill the 16:9 (cinema mode). I ended up with brighter images on the sides compared to the 4:3 center images.
    My only fix was to create a DVD that was reversed. I created a 16:9 DVD that had black in the 4:3 center and white in the 16:9 outside bars. I ran the DVD over night for a copy of days and the picture equalized out.
    My plasma is a 2nd generation, 4th-7th plamsas really don't have this problem anymore. Most better brands have built-in stuff to keep this from happening
  7. plasma, rear-projection, CRT, LCD
    So what kinds of TVs are left? Doesn't that pretty much cover it?
    Darryl
  8. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    DLP aren't susceptible to burn in, right?
    What We Do In Life, Echoes In Eternity....
  9. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    "Burn in" is a problem of Plasma screens.
  10. Member edDV's Avatar
    Mar 2004
    CRTs will develop this problem over a long period of time. You see it in lower end broadcast monitors that have been running in underscan mode to show the edges.
    I have this problem on a older Sony XBR Trinitron that has "S-Video" burned in to the screen.
  11. Originally Posted by Denvers Dawgs
    Correct. DLP's can never develop burn in. They are based on a micro-mirror device that does not degrade over time from use like is the case with CRT, plasma, LCD, etc.
