When I download certain files I get a audio sync problem which dosent seem to happen to others. I think I have all the relative codecs installed through K-Lite codec pack but not sure. Does anyone have any ideas.
Not enough information to make a guess.
What type of files? What type of audio, what type of video?
Since you have a K-lite codec pack, that would be a prime suspect. That program has messed up a lot of computers, that's one reason we don't include it in 'Tools' anymore because of problems it has caused.
Drop one of your problematic files into Gspot 2.60 and post a screenshot here. Blank out the titles with MS Paint.
Also are you just playing the files or are you converting them to a different format? The conversion is usually where the sync problems show up. If you have a Divx or Xvid with MP3 VBR audio and you try to encode that to MPEG, you will likely have a sync problem. -
Just found that the problem is only when I play it with Nero showtime 3 when I use windows media player it's perfect. Just have to play it with this. What do you suggest to install necessary codecs to download and burn avi,xvid and mpeg files also should I delete already installed codecs.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
