Hi,
I converted AVI (DiVX) to DVD via AVI2DVD, but probably I choose wrong encoding for subtitles. Is there some simply way how to change encoding of subtitles or must I re-encode the whole DVD again (thru AVI2DVD)? Thanks for help in advance.
how do you check the subtitles? you might have to manually enable them in your software dvd player or/and standalone dvd player.
Well, I checked it on Apple via VLC Player and DVD Player. The subtitles was added as "custom made" so I think I choose wrong encoding, because several specific characters have just "underlay symbol". So it is possible just to add "new" subtitles to ISO or must I re-encode whole DVD once more ?
Don't know about the Apple world, but there are plenty of ways to add subtitles to an already authored DVD using PC software
https://forum.videohelp.com/viewtopic.php?t=275603
https://forum.videohelp.com/viewtopic.php?t=245188
https://forum.videohelp.com/viewtopic.php?t=219535
Are but threeRead my blog here.
Converting HD-DVD subtitles To BLURAY subtitles
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 7th Sep 2014, 07:15 -
How to add Subtitles to original DVD whitout loosing original subtitles ?
By Chainsaw_1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2010, 13:52 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 18:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 10:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 17:28
