I have several short movie clips which I want to send by e-mail whats a good program to compress these down
Since your profile shows you have XP SP2, why not try Windows Movie Maker. It's part of the package and is easy to use. It will even create the email for you!
It can create quite acceptable files in .WMV format suitable for email.John Miller -
I second Johnny's Windows Movie Maker solution.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
where on xp is windows movie maker as I have looked in accessories and cannot find it
It's usually straight off of All Programs.
If not, you can find it at "C:\Program Files\Movie Maker\moviemk.exe"John Miller
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 18:30 -
I need a video compresser
By stranzer in forum Newbie / General discussionsReplies: 6Last Post: 11th Oct 2009, 01:17 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 3rd Nov 2007, 00:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 13:49
