    Dec 2001
    Edmonton Alberta
    When converting DivX to SVCD w/ TMPGEnc 2.01 sometimes i get a Ilegal Floating Decimal Point Calculation Order Error like part way into conversion... When i try to view the DivX at the source time the error took place the video freezes but the audio track continues on. If you move the video track forward a little bit the rest of the DivX play just fine. Is there a utility to fix these screwed up DivX files or are they toast?
    Thanks in Advance
    James
  2. Member spidey's Avatar
    Apr 2001
    U.S.A.
    I;'ve had this before too. What you may try to do is up the priority of your DIRECT SHOW MEDIA FILTER.
    Open TMPG, go to OPTION, ENVIRONMENTAL SETTING, VFAPI Plugin tab, rt. click DIRECT SHOW, and up it's priority.
    Hope this helped.
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
