copied the video folder from a non-encrypted dvd with 4:3 display aspect ratio. using virtualdubmpeg2 opened the video but noticed it was stretched sideways. how do i save this video to dv avi format and keeping the aspect ratio? any help will be greatly appreaciated. thanks
First you need the panasonic DV codec installed so virtualdubmpeg2 can create a DV avi for you.
Not sure what you mean by stretched sideways. If the DVD plays back fine then it can only be in one of two formats to appear distorted. It is either 16:9, or half-D1.
A simple way to test. Open the mpeg in virtualdubmpeg2 (that latest version, I assume), right-click on the preview window and choose 4:3. If the image looks OK, it is half-D1. if it doesn't, right-click again and choose 16:9. If the image becomes wider, but everyone it in looks normal, then is is 16:9.
For half-d1, go Video -> Filters. Add the Resize filter and set the size to 720 x 480 (576 if it is PAL). You can now save it out as a DV avi file.
If it is 16:9 then it is a little more complicated.
Video -> Filters. Add a Null Transform filter and click OK. You can now press the Cropping button at the bottom of the filter sheet. Set the y1 and y2 offset values to 60 each (72 if it is PAL). Click OK, then OK again to close the filter sheet.
Again, video -> filters. This time Ad the Resize filter. Set the New Width to 720, and New Height to 360 (432 for PAL). Tick Expand Frame and Letterbox Image and enter 720 and 480 (576 for PAL) for Width and Height. Again, save out as a DV avi.
Note : if it is 16:9 you will have to have letterboxing (black bars) to make it look right on a 4:3 display. However DV does support 16:9, so it depends on what you are going to do next as to which is best.Read my blog here.
anyway, thanks a lot gunslinger. you helped me solved another problem again.
Save in Old 1.0 avi format
By jliggett in forum Video ConversionReplies: 5Last Post: 29th Mar 2011, 17:31 -
how to save a videoclip in .mov format
By marlo in forum Newbie / General discussionsReplies: 0Last Post: 11th Nov 2010, 00:53 -
Howto 4:3 movie save to 16:9 format
By eMCe in forum ffmpegX general discussionReplies: 3Last Post: 16th Feb 2010, 13:27 -
Best format to save AVI files on PC
By bpatters69 in forum Video ConversionReplies: 6Last Post: 31st Mar 2008, 08:31 -
question about "save old format avi" with Vdub
By mr-scarface in forum EditingReplies: 3Last Post: 5th Sep 2007, 21:34
