  1. Member Soopafresh's Avatar
    Jan 2004
    http://www.gigavox.com/levelator
    Works only on WAV and AIFF files. Versions for both Windows and OSX
    Requires Java JRE 1.5 (Next version promises to be Java Free
    See post below to use in command line mode without Java.
  2. Member Soopafresh's Avatar
    Jan 2004
    Edit - Looks like the Windows portion isn't actually Java dependent. To use the executables only, download http://www.gigavox.com/levelatorDownload/lib/win-binary.jar . Unzip the .jar file like you would any .ZIP or .RAR file. Inside, you'll find the Level.exe and Libsndfile.dll files. Put them in the same folder as the WAV file you wish to process, or place them somewhere in your path.
    Syntax is :
    Level input.wav output.wav
    The effect isn't as harsh as some compressor/normalizers out there. Quite natural sounding.
    Oct 2006
    Brazil
    take care with levelator Soopafresh!
    i'm sure that you don't will like the result with musics like "mother - Pink Floyd" where the sound start quiet and have one abrupt change in the levels.
    try first with musics that have this condition!
    see pictures before and after levelator:
    http://img177.imageshack.us/my.php?image=normalqu7.png
    http://img140.imageshack.us/my.php?image=levelatorsp7.png
    the white area is the low/high volume transitions
  4. Member Soopafresh's Avatar
    Jan 2004
    It isn't for music maximizing. The better application is for low dialogue - where you can't hear one person speaking.
    Oct 2006
    Brazil
    in this case is very cool!
