Hey guys,
This might be tad complicated but I still hope I get a solution. Its like this - I formatted my PC yesterday and the rest of the day went in installing and tweaking stuff. At the end of the day, I installed all my Codecs (K-Lite Codec Pack) and began watching a DivX movie. The moment the movie began, I could see that all the color settings were haywire. I concluded that it must be the Overlay mode color settings that were messed up. This was because, no matter which Media Player i used to watch the movie - i got the same old discolored video. I began fiddling around a bit and found the place where I Could rectify it - the Nvidia control panel. Now its asking me to set all sorts of things such as Gamma, Hue, RGB, Saturation and all the other jargon. I have basic idea of what each one does but I'm not able to calibarate it cause i need something as a benchmark. How do set it? When i try to watch a small video clip and set I dont get good results as i dont know what figures to feed into the different boxes.How do i do this? The moment i slightly increase the Gamma, the whole video becomes one big flash of light and the moment i reduce it, it goes pitch dark. What values should i use for the settings?
Thanks in advance guys.
Results 1 to 11 of 11
Video drivers often mess up the overlay settings when first installed. So first disable overlay and exit the dialog. Then go back and reenable overlay. That may be enough to fix the problems you are encountering. Then you can fine tune all the settings if necessary.
No substitute for doing it right.
THX alignment patterns are availalable on many DVD discs.
List of DVDs
http://www.thx.com/mod/products/dvd/dvdFind.html
http://www.thx.com/mod/products/dvd/optimizerIntro.html
Or,
start with a color bar pattern
http://www.belle-nuit.com/testchart.html
and adjust by the normal technique
http://www.videouniversity.com/tvbars2.htm
http://www.indianapolisfilm.net/article.php?story=20040117004721902
In your case, follow PAL settings.
The most basic adjustments are.
- Set black level with "Brightness"
- Set white level with "Contrast"
- Adjust gamma so all ten luminance steps are visible and about equal
- Adjust color "saturation" to taste
- Adjust "Hue" to get correct colors. -
Originally Posted by jagabo
How do I disable overlay? I have a Nvidia 5200FX and the regular Nvidia drivers. I cant seem the find the setting anywhere.
Hey edDV,
How would I be able to get a colour bar pattern into Overlay mode in Media Player Classic. My desktop colours are fine so I'd i have to view the image in Overlay mode but how do i do it? -
Originally Posted by mridang_agarwal
Rec-601 levels 16 black, 235 white as used in MPeg2, MPeg4. The chart also shows 0-255 markers. -
Isn't it generally accepted that the worst thing you can do is install a codec pack? Most recommend ony installing individual codecs one at a time as needed. There have been a number of threads on here where people have had display problems which were cured by uninstalling codec packs.
If you convert the image to an MPEG file be aware that most encoders will compress the luma range of an RGB source so that all YUV luma values fall between 16 and 235. So the patch labeled 0 will become 16, 4 will become ~19... 255 will become 235. On conversion back to RGB (loading into a program like VirtualDub) the opposite will happen. YUV luma 16 will become RGB 0, etc. -
I agree the BMP is the most direct and least error prone way to go.
If you pull the tif or BMP to full screen on your desktop (no overlay), you can also see how close your computer monitor brightness, contrast and RGB levels are set.
If for just watching, your goal is to get close and adjust it for your personal taste.
The first things to check are black and white levels. Black is most sensitive. A computer monitor desktop should be seeing 0-255. If you see no difference between 0, 4, 12, 20 then you need to adjust "brightness" up*, then tone down contrast until 255, 251, 239 show difference vs. 235.
For overlay, you should see little or no difference between 0, 4, 12 and 16. 20 should show some difference moving from black to very dark gray. Adjust until you see a little difference. Otherwise you have crushed black levels. At the white end 231 to 255 steps should be visible.
If you are producing video for others to watch, you need to get very anal about getting these set precisely. Otherwise the user of your video will see shifts vs. commercially produced material.
* If you can't get there, make sure the 16 to 21 step is adequate. Fine black level sensitivity is a sign of a quality monitor. -
Read this.
http://en.wikipedia.org/wiki/Video_overlay -
Originally Posted by edDV
Originally Posted by mridang_agarwal -
I, reset my overlay mode (By first turning Hardware Acceleration all the way down, rebooting, and then turning it all the way up). The result - nothing!
Now, off I go to try the second way. I'll try it out and post the results here. Sorry for replying slowly guys, I've been kinda busy and I really appreciate all the help I've been getting from you. Cheers!
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
Changing Night Mode Cam Video to Normal Colour or B/W
By Mr Baldman in forum RestorationReplies: 2Last Post: 3rd Jan 2009, 04:06 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 15:27 -
Vegas 8: Overlay text in multimcamera mode?
By stantheman1976 in forum EditingReplies: 0Last Post: 4th Feb 2008, 13:08 -
Deep Colour/xvYCC colour/x.v.colour confused consumer
By ArthurDaley in forum DVB / IPTVReplies: 10Last Post: 9th May 2007, 18:10
