hi,
im tring to follow this guide
https://forum.videohelp.com/viewtopic.php?t=219535
that explain how to add and srt sub to an exsisting dvd movie with dvd-lab pro .
Now, in order to make sure my srt sub is sync with the movie i converted the dvd to an avi and run them both in subtitle workshop and the match was perfect .
neverthelese my output project is suffering from a 1+ seconds sync problem , which i cant explain why this is happening .
i tried also a pal project and a ntsc project (in dvd-lab pro) but the same sync problem occured.
and i also cant just set a delay to the srt in subtitle workshop because over there as i said the match is perfect.
anyone know why this could happen and is there a way to avoid it ?
thanx .
p.s
sorry for posting it here and not in the guide post but there it so old no one is watch it for answer question , the only one who watch it is a newbie like me .
Try using DVDSubEdit for moving your subtitles to the correct place.
ericf -
hi, the same problem, please, help
It' s works great.
Now, in order to make sure my srt sub is sync with the movie i run them both in subtitle processor 7.5 and the match was perfect (my .srt was edit and sync with subtitlr processor 7.5)
nevertheless my output project is suffering from a 1+ seconds sync problem , which i cant explain why this is happening .
anyone know why this could happen and is there a way to avoid it ? (Original movie is Ntsc).
thanx .
Pink
vilmlabu@bamba.lt -
I can't say what the problem might be in DVD Lab Pro, but if the problem is with the srt file, VisualSubSync is a god send. It shows you a visual representation of the audio to sync the subtitle to. Very easy to use, and dead on accurate sync.
i had a the same sort of problem a couple of days ago,
heres my post
https://forum.videohelp.com/viewtopic.php?t=315561&highlight=
Heat added
By alintatoc in forum ComputerReplies: 25Last Post: 27th Aug 2011, 09:06 -
AVI files refuse to be added
By johnbrigden in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 14th Jul 2010, 12:05 -
Could the definition for h264 be added to the glossary?
By yoda313 in forum FeedbackReplies: 2Last Post: 27th Jun 2010, 07:50 -
idx/sub/sup problem when to be added to dvd
By StarX in forum SubtitleReplies: 4Last Post: 19th Jan 2009, 23:34 -
Added subtitles too wide
By gnappa in forum SubtitleReplies: 12Last Post: 21st Apr 2008, 02:45
