Hello,, I am so new at this that water is still driping from behind my ears..here are the questions/concerns i have
i have 8mm tapes of my son i NEED to convert to dvd, i tried dazzle cards and others and they are sitting in a draw, so came here and decided to go w/ a conveter (canopus, 110 or 300) is there any other companies that make conveters like this?
2nd, should i buy a vcr that plays back 8mm tapes and NOT use my camcorder?
and also i have vcr tapes, reading over other topics, says better to use a vcr w/ TBC, so should I get a newer one vcr player?
thanks for bearing w/ me
ron
I'm not sure about the converter, and many people get good results using the dazzle cards.
Your camcorder should work just fine to output the video.
The type quality of the VCR needed will vary according to the quality of your tapes. Unless you tapes are in bad shape, you should be able to get decent quality from most players.Google is your Friend
questions on using "pass through", converting analog to digital
By tadd5181 in forum Video ConversionReplies: 4Last Post: 27th Apr 2010, 17:59 -
Portable PAL analog (yes, analog!) television set
By stuey123usa in forum Capturing and VCRReplies: 0Last Post: 22nd Jun 2009, 19:23 -
Analog to DV Tape vs. Analog directly to computer
By jlorelle in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 7th Sep 2008, 09:45 -
Capturing questions... IRE, analog->digital differences, and more!
By binister in forum Newbie / General discussionsReplies: 5Last Post: 20th Jan 2008, 15:33 -
Capturing Analog Video: Device Options (Survey/Questions)
By SHVideo in forum Capturing and VCRReplies: 6Last Post: 12th May 2007, 20:19
