I'm a new user. I only use ffmpegx to encode files for DVD. Unfortunately, it seems that ffmpegx encodes the .mpv and .ac3, but also the muxed .mpg, which I don't need at all. Is there a way to disable creation of the .mpg file?
Also, is there a way to save my preset in the quick presets instead of just to a file and having to load it every time I use the program?
Thanks,
Sebastian
I usually go the other way (DVD -> divx) so I know nothing about the disabling the muxed file.
However, instead of opening ffmpeg, you should open the preset (by double clicking or however you would normally open ffmpeg: throw it on your dock for easy access). That way you're doing "just as much work" but your preset automatically loads. You can even call the preset ffmpegX.ffx if you want.- David the Newbie
3d questions
By alucard2050 in forum DVB / IPTVReplies: 16Last Post: 21st Aug 2010, 23:01 -
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 15:50 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 18:08 -
Some Yes or No questions
By the_importer in forum Media Center PC / MediaCentersReplies: 22Last Post: 3rd Jul 2008, 18:06 -
Got a new 16:9 TV, have some questions...
By sdsumike619 in forum Video ConversionReplies: 6Last Post: 28th Jul 2007, 14:00
