I have few question about cedocida dv codec.
Firstly i capture with canopus 110 so my captures are dv avi files(interlaced,Pal)
I am also using CCE and want that my captures be in YUY2 colorspace.
1. For Decoder option in cedocida, if i want that my captures be YUY2, does i must to check force output format and check YUY2 ?
Also for decoder option what must to be select: 16.235-0.255 or 0..255-0..255 ?
2. And for Encoder options does i need something to change ? Again my goal is yuy2
thanks
Results 1 to 15 of 15
You cannot capture with this codec. The 110 will convert the analogue signal to DV using a hardware based codec (probably a hardware version of Canopus's DV codec). You can only convert your DV to Cedocida's YUY2 by re-encoding. What do you gain by doing this ? Nothing unless you have filtered through avisynth filters that work in the YUY2 colourspace, and save through virtualdub using fast recompress mode (and no virtualdub filters).
Once again - you cannot capture using Cedocida DV codec (or any software based DV codec) without re-encoding if you transfer DV source (and using the 110 means you have DV source when it reaches your PC)Read my blog here.
Since you are using cedocida to decompress DV and send it to CCE, cedicida's encoder settings don't matter.
If you don't force an output color format cedocida and CCE will negotiate the best color format to use. This will most likely be YUY2 so the other decoder settings don't matter.
I have noticed lately that cedocida has a problem with color decoding at the far right of the frame. The last 16 pixels or so. Here's a 4x enlargment from the far right of a frame:
This is from an NTSC video. I don't know if PAL has the same problem. -
In Decoder if don't force an output format, then colorspace will be YV12. I now tested this
But if force an output format, then colorspace will be YUY2.
That was my first question. So if we want YUY2 we must select option:force an output format(and chose yuy2) in decoder option.
What about encoder settings? -
Ah, it's different for NTSC and PAL. On NTSC DV it outputs YUY2. This makes sense because DV is 4:2:0 in PAL systems and 4:1:1 in NTSC systems.Originally Posted by SerbianBoss
Why is this necessary? Are you encoding MPEG2 with 4:2:2 subsampling? That would be rather unusual. I know the MPEG2 spec supports this but I don't know that CCE does. If you are using the more common 4:2:0 subsampling for MPEG2 then forcing cedocida to output YUY2 is a waste of time. You are taking 4:2:0 video from the DV file, converting it to 4:2:2 (YUY2), then CCE will convert it back to 4:2:0 before compression. And even if you are encoding MPEG2 with 4:2:2 subsampling, the only difference is who does the conversion from 4:2:0 to 4:2:2 -- cedocida or CCE.Originally Posted by SerbianBoss
Going from DV to CCE you are not encoding DV. You are decoding DV.Originally Posted by SerbianBoss -
I forced output to get YUY2. Its important because CCE work with yuy2 material. So i want to feed CCE with yuy2 colorspace.
With cedocida dv codec i only get yuy2 if i forced output and select yuy2. -
You could do this much more simply with avisynth.
If you are using virtualdub to frameserve because you want to use filters then using the cedocida DV codec to decode will not make any difference. As soon as you add a filter, virtualdub will move the video into the RGB colourspace to process it.Read my blog here.
The version of CCE I am using accepts RGB, YUY2 and YV12 for encoding. Is there some processing function within it that only accepts YUY2?Originally Posted by SerbianBoss
<edit>
I may have found the difference. In CCE, under Options -> Misc, on the Misc tab there is an option labeled "Try decoding in YUY2 format". With that option checkmarked it accepts RGB, YUY2 and YV12 from cedocida. Without the option it only accpets YUY2. -
John Miller
Yes, i opened dv avi directly in CCE(not frameserving) or make avisynth script and open dv avi file in cce
So what to do? My goal is YUY2 colorspace. Does is proper way if i in cedocida to force output format to YUY2? All filters whitch i work get in YUY2 colorspace not YV12.
So,i capture,make avisynth script i send script to CCE. Because of that i want to get yuy2. Is that right?
Cedocida DV codec with VirtualDub
By tsu3000 in forum Newbie / General discussionsReplies: 1Last Post: 26th Nov 2010, 16:32 -
How can I edit cedocida codec settings in windows 7?
By dssdss in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 9th Sep 2010, 03:10 -
Cedocida DV Codec - 16:9 not recognised?
By BertRito in forum Newbie / General discussionsReplies: 30Last Post: 11th Jul 2010, 21:50 -
Cedocida still the only DV free DV encoder to use?
By sphinx99 in forum Video ConversionReplies: 0Last Post: 19th Mar 2010, 22:45 -
Codec (Cedocida) Questions
By Bob Carruth in forum Newbie / General discussionsReplies: 11Last Post: 1st Mar 2009, 22:04
