Is there any software that will create an AVI out of a screensaver? I know FRAPS does this for games, but it won't work for screensavers. Thanks
Results 1 to 10 of 10
Excellent program. It did the job fine. My only question is: how to capture to fully uncompressed AVI? Because in the Video Options of this program, only several compressors are listed, there's no option for fully uncompressed. Thanks.
What is your system configuration? Fraps is optimized for dual-core, but also works with my standard computer with a GeForce 6200. You need a fast machine to capture high-res smoothly. My Fraps settings are Movies: 29.97, record sound, detect best sound input. Thats all. I use the F9 key to start and stop captures.Originally Posted by alegator
I too am trying to record a screensaver with Fraps... I've tried CamStudio with the lossless codec mentioned above but CamStudio only records up to 3fps... Fraps is amazing when playing games (GTA:SA) but I can't get it to record a screensaver... When I press F9 to start recording the screensaver closes... obviously... but it sounds like "nicksteel" was able to do it... Can you explain farther?Originally Posted by nicksteel
Thanks -
Many screensavers exit on any key press. The ones I've done have setup option to exit on "Escape" only. Also, you can select another Fraps key other than F9. Even if your saver exits on any key, some have a setup key (space, enter, etc) you can press while it running. If so, try to set Windows Task Manager priorities while in this setup mode and start Fraps before exiting.
I have also found that you should defrag your capture drive, whether or not defrag says you need it. Also, I use Windows Task Manager (Ctl Alt Del) to set Fraps priority to Realtime, screensaver to Abovenormal, after turning everything I can off (virus protection, firewall, etc). Be sure to reboot after capture to enable everything again!
Trying to capture hi-res screensavers is a bit challenging at times, but I like to encode anamorphic widescreen for my plasma and this needs a good source for ending up with good dvd's. I am encoding with HCenc to 720x480 overscan 2 with avs settings from FitCD.
Using Avysynth allows me to join the many Fraps 4GB files with "++" and process without sound sync problems. I extract the audio as a wave file with VirtualDub, convert to mp2 and mux with m2v vide with Mplex as DVD. I edit out the dupicate frame sections between files in VideoReDo, after creating final mpg file. I then use DVD-Lab Pro to make DVD.
Which screensaver are you working with? All this is not really complicated, just sounds that way. The processing can be pretty slow, but I let everything long run overnight.
Keep on trying! -
here is a article about it :
How to re-record other video files playing on the screen
Looking For A Free Video Screensaver
By DJboutit in forum Newbie / General discussionsReplies: 2Last Post: 6th Apr 2012, 14:29 -
Restoring capture from Windows Movie Maker .tmp file
By markm96160 in forum Capturing and VCRReplies: 3Last Post: 17th Nov 2008, 15:37 -
ScreenSaver to AVI -MPEG
By arturjose in forum Video ConversionReplies: 3Last Post: 25th Oct 2007, 10:03 -
Convert screensaver files to some form of movie?
By michaelmcgennan in forum MacReplies: 3Last Post: 27th May 2007, 09:41 -
Capture DVD movie from a DVD player to a WMV file on my PC
By JBredensteiner in forum Capturing and VCRReplies: 4Last Post: 22nd May 2007, 02:49
