I have a Dell OEM WinXP OS installation CD that came with my Dell PC. It has over 4 years and it's time to make a backup of it just in case it gets scratched, etc. What's the best method to make a clone CD? I guess there's lots of software for this (Nero, etc), just would like advise on the most reliable/precise method given that it's an OS installation CD. Thanks.
If you've got Nero, that should work.
I don't think there is any copy protection on Windows CDs, but it'll be bootable, to retain that it does need to be cloned rather than just copying the files as data.
If you're planning a reinstall, you may be interested in slipstreaming service packs and patches into the disc image.
See eg HFslip and elsewhere on that forum. -
Both clone cd , and nero will copy it ... but you will need to test it using a spare empty hd ... just checking for error's during install is the only method to guarantee it is perfect .
The problem will be the drive used to make they copy ... liteon is the best ... sony , and lg next ... other's may produce an inferior copy ... but do try clone cd on the slowest read setting possible will help with other units . -
Thanks everyone for their response. I tried slipstreaming on the Dell OEM WinXP CD and it's a headache. What I do on every clean install is:Originally Posted by AlanHK
1) Install WinXP pre SP1 using the Dell OEM CD.
2) Install SP2 using the Microsoft SP2 offline file (I have it in an external hard drive)
3) Install all current updates using Autopatcher XP (again file in external hard drive)
http://www.neowin.net/forum/index.php?showforum=89
This has proven to me to be the fastest, simplest,safest and most successful method.
System slows down after cloning
By mysts in forum ComputerReplies: 5Last Post: 2nd Jan 2011, 06:52 -
Cloning a format.
By Noggin in forum Video ConversionReplies: 4Last Post: 8th Sep 2009, 19:01 -
Mac Address Cloning---again
By danl_9x in forum ComputerReplies: 0Last Post: 6th Mar 2009, 21:48 -
cloning my pc desktop to tv
By RottieGirl in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2009, 15:35 -
What is the best dvd cloning free software for the mac?
By Jabroni4872 in forum MacReplies: 9Last Post: 7th Nov 2008, 10:10
