Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. Member rakf1's Avatar
    Sep 2006
    Guide to encode WMV file with multi-language audio tracks
    Tools required:
    Windows Media Encoder
    This document describes the basic instruction for creating a WMV file with multi-language audio tracks. The tool used is Windows Media Encoder which is free software available from Microsoft website.
    Index:
    1. Encode 1 Video (WMV) and 3 Audio (WMA) files
    2. Edit Windows Media files to same length/duration
    3. Mux 3 WMA tracks with the WMV video
    4. Verify that final encoded WMV file has 3 audio tracks
    1. Encode 1 Video (WMV) and 3 Audio (WMA) files:
    Use Windows Media Encoder to create a WMV video only file and three WMA audio files with different language settings for each as described below. You can also create 1 WMV with audio file and 2 WMA audio only file.
    • Open Windows Media Encoder from Start -> Programs -> Windows Media
    • Select “Custom Session” as shown in the screen-shot below:
    • Under the “Session Properties” -> “Source” tab, select the ‘source form’ as ‘File’ and browse the source video or audio file as shown in the screen-shot below:
    • Under the “Session Properties” -> “Output” tab, select the ‘encode to file’ option and select a output file name as shown in the screen-shot below:
    • Under the “Session Properties” -> “Compression” tab, select the ‘edit’ button and set the encoding option like bitrate and language option, as shown in the screen-shot below:
    • Make sure that all WMA files are encoded with same bitrate settings.
    2. Edit Windows Media files to same length/duration:
    This is a optional step required only if the WMV and WMA files are of different durations. If all the files have same duration, then skip this section.
    • Open Windows Media File Editor from Start -> Programs -> Windows Media -> Utilities
    • Open the WMV/WMA files and use the Mark In/Mark Out options to edit the files to the same duration and save.
    3. Mux 3 WMA tracks with the WMV video:
    • Open Windows Media Stream Editor from Start -> Programs -> Windows Media -> Utilities
    • Select “Add Source…” and browse to the folder containing WMV and WMA files.
    • Select all the WMV and WMA files
    • Expand all the source files and check the box for Video and Audio as shown in the screen-shot below:
    • Select the “Add ->” button, the Output audience should appear as shown below:
    • Select “Create File…” and type a file name for output file and click the start button.
    4. Verify that final encoded WMV file has 3 audio tracks:
    • Open the created WMV file in Windows Media Player
    • Verify that a audio track is playing along with video
    • From the Play menu, select “Audio and Language tracks” and verify that the 3 audio tracks are available as shown in the screen-shot below:
    • Verify that selecting a different audio language track will play that particular audio track.
    Mar 2014
    singapore
    thanks
