i have a problem with renaming any files on my computer. when i rename a file i get error messaging saying that file will become unusable, and then i doesnt open anymore.
Do you see file extensions or not? If you do see them, than perhaps you are renaming whole file without the extension.
moved to another forum, nobody likes me here... -
he wouldnt get that warning if he was just renaming the file :/Originally Posted by fLYtRap
that's because you are attempting to change the extension along with the name, for example:Originally Posted by peomp
if you rename example.bmp to example2 the OS won't know what type of file it is and thus won't know how to open it. when you go to rename the file, it's important that you remember to keep the 3 letters after the dot the same:
you should also go to into your folder options and change the options so that the file extension isn't shown with the name, then you won't run into these kinds of problems. -
grrr now i understand what he meant x.O
yeah like deadrats said.....control panel>folder options>view>make sure "Hide extensions for known file types" is clicked ^ ^ that way when you rename anything it keeps the same extension -
the error message comes to any file with any ext.
for example: rename file1.bmp to file1a.bmp, gives me the error every time.
thanx guys...i went into the folder option and check hide extensions, that did the trick....once again thanx!!!!
Renaming AVCHD file using timestamp
By cheerful in forum Newbie / General discussionsReplies: 3Last Post: 9th Jun 2011, 08:10 -
Windows 7 Upgrade Makes Some PCs Unusable
By deadrats in forum ComputerReplies: 88Last Post: 5th Dec 2009, 04:14 -
Orbit downloader - faded commands unusable
By chis@ in forum Video Streaming DownloadingReplies: 2Last Post: 29th Jun 2009, 01:58 -
Unusable results from VHS to Digital Conversion (Long)
By ZARTT in forum Newbie / General discussionsReplies: 11Last Post: 4th Feb 2009, 01:16 -
Burned an MPEG2, replicator says it's MPEG1 and unusable?
By First1 in forum Authoring (DVD)Replies: 4Last Post: 11th Nov 2007, 13:55
