Results 1 to 10 of 10
    Croatia
    Hi,
    I've bought my first DVD player which supports DIVX and MPEG4.
    It's Smartvision model 935. The first day I bought it, I upgraded the firmware because of a better subtitle support for my native language. It seems that it has Mediatek chip inside, which is probably a good thing.
    Darn thing plays all version of DIVX very good and smooth with excellent support for subtitles in srt, sub, ssa...
    But there is a problem with some XVID files. While it plays the most XVID's, some XVID's plays slow and "jumpy". I've checked those files with AVIcodec and I can not see anything different from other XVID's which play fine.
    I would like to know why this problem occurs and is this a case with other similar players? Thank you.
    By the way, I burn those avi files and their subtitle files on Verbatim DVD discs.
  2. Member steveryan's Avatar
    Jan 2003
    Manchester
    Sounds like packed bitstream, use MPEG4Modifier to unpack.
    He's a liar and a murderer, and I say that with all due respect.
    Croatia
    Hm, strange.
    I was just about to tell you that I've already tried that, but MPEG4Modifier refused to open those files, when I decided to try again and now it does open those files.
    I'm going to try that and I'll report back.
    Thank you steveryan.
    Croatia
    OK I used MPEG4Modifier to open the sample file and to unpack bitstream. After that I burned the resulting file to CD and tried it in my player, but the problem remains.
    These are video informations before unpacking:
    Packed bitstream: Yes
    QPel: No
    GMC: Yes (3 warp points)
    Interlaced: No
    Aspect ratio: Square pixels
    Quant type: H.263
    FourCC: XVID
    User data: DivX999b000p
    XviD0036
    and after unpacking:
    Packed bitstream: No
    QPel: No
    Interlaced: No
    Quant type: H.263
    FourCC: XVID
    User data: XviD0036
    Any further hint, please.
    Thanks jagabo for the link - nice reading. It seems that GMC is the problem, isn't it?
    General information from AVIcodec are:
    Video : 453 MB, 823 Kbps, 23.976 fps, 656*288 (2.21:1), XVID = XVID Mpeg-4
    Audio : 246 MB, 448 Kbps, 48000 Hz, 5 channels, 0x2000 = AC-3 ACM Decompressor
    Thank you.
  5. Yes, it looks like GMC is the problem. You will have to reencode.
    Croatia
    I could watch those problematic XVID files on my laptop or my desktop which has s-video connection to my TV, no problem, but I'm just curious about reencoding.
    What options would you choose to reencode that particular video?
    Thanks.
  7. I would use VirtualDubMod. The basic procedure after starting the program:
    File -> Open Video File
    Video -> Fast Recompress
    Video -> Compression... select Xvid, press Configure, press Load Defaults.
    File -> Save As.
    That will probably make the file a little bigger but it's fast and easy.
    A lot of people use a program called AVIRecomp for this. I don't know anything about it though.
    Croatia
    Thank you very much, jagabo. I appreciate your help.
    I will try the reencoding.
  9. Of course "fast" is a relative term here!
