Hi,
Does anyone know of a simple tool to convert a .mp2 audio track to a wav file.
( Have need to touch up a audio track on a VCD , LOTR )
Thanks in advance
WinAmp will do audio export
dbPowerAmp (link in the tools section) will do it
SoundForge will open it into wav
CoolEdit will open it into wav
--- I do WinAmp output to wav (Options->Prefrences->Plug-In's[select Output] and change Nullsoft wavOut to Nullsoft Disk Writer) ... i just find it easiest --- then I do Noise Reduction / Editing in Sound Forge
then convert back with tooLAME
your pal,
Stinky
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
6ch Wav to 2ch stereo wav
By ranosb in forum AudioReplies: 12Last Post: 15th Jul 2009, 22:45 -
mp2 & wav compatible DVD authorers?
By Bassquake in forum Authoring (DVD)Replies: 4Last Post: 2nd Feb 2009, 14:11 -
M2V + 2 WAV files to VIDEO_TS with 2 PCM soundtracks (not mp2)
By cleantone in forum MacReplies: 14Last Post: 28th Aug 2008, 15:10
