I thought I would archive some TV footage recorded on my Panasonic EX75 recorder. So first I copied from the Recorder's HDD to a DVD-RAM disc. It contained about 12 clips, with a total length of 32 mins recorded in SP mode. When I transferred these clips from the DVD-RAM disc to my PC's hard drive, all the clips were joined as one, in 1 VRO file = 1.2GB.
I renamed the extension to MPG, with the hope of going through TMPGEnc 4.0 XPress, and editing/cutting the clips into their individual files, and coverting to xVid along the way.
However for some reason the clips are showing in the timeline, as all over the place, and not in the sequential order, they were originally copied to on the DVD-RAM disc. Also some of the clips when viewed back in the timeline, contain audio from other clips. It's also showing 2hrs 20mins as the total length, when I know it's only approx 32mins long.
I have managed to cut/edit 3 clips that were displayed fine, without any audio sync problems, but wonder if anyone could tell me how I can go about, editing out the other clips.
I know the 1.2GB source file is okay, because I have played it through PowerDVD without any audio sync problems, and the clips all play in the correct order.
So is the corruption occuring when I copy the VRO file from the DVD-RAM disk to the hard drive, or when I rename the extension to MPG?
Womble MPEG Video Wizard does sound great, but I'm not looking to pay so much, unless it's something I will be doing on a regular basis.
The only TMPG product I have got in the XPress 4.0 version. It doesn't have any Import DVD Video options, you just open a project and import your clips.
Cheers - I will try IsoBuster, and see if that helps.
It seems to be in the copying. It was the same sort of problem, file sizes that didn't make sense, out of order video, mismatched or absent audio. Renaming to mpg or vob didn't make a difference. Neither did demuxing. My guess was I didn't have a needed driver. After about four months of the same problem, I broke down and spent the money on the pro version and it worked. It can also read unfinalized -rw, I found out recently. Nice when I put the wrong type of disk in the recorder
Took me awhile to find it again but I use the Panasonic Movie Album software with the Copy Tool. This will see the separate programs on a DVD-RAM and let you transfer them to your computer. If you want to get the disc from a Panasonic repair depot the disc is part number LSFT0643-1A. There are also updates to the software. Now to make sure I keep this somewhere I can find it in case I get another hard drive crash.....
XviD Quantization type, H.263 vs MPEG; and GMC for hand recorded material
By carlaron in forum Video ConversionReplies: 41Last Post: 2nd Mar 2010, 22:36 -
i recorded a show from my dvr to my dvd recorder
By billrhonda in forum Newbie / General discussionsReplies: 4Last Post: 6th Jan 2009, 10:48 -
Panasonic DMR-EZ28 Previously Recorded Panasonic DVDs
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Oct 2008, 20:45 -
DVD Editing from Panasonic VDR-D220 Mini DVD and interlacing problems
By gbnz in forum EditingReplies: 3Last Post: 15th Oct 2008, 14:34 -
Editing recorded material made by DVD recorder
By sallywil in forum EditingReplies: 2Last Post: 26th Aug 2007, 19:58
