I'm trying to burn a few more videos to dvd and having problems no matter the software used to burn. I keep getting Audio stream issues by programs. Or access violation to the avcodec.dll in convertxtodvd. I think that the audio might be at the wrong frequency. What is the best way to recode it be 48000hz? According to the info from convertxtodvd its 24000hz which could easily be the problem. Thanks again guys.
Use VirtualDub its easy and free
Guide here
https://www.videohelp.com/virtualdubaudio.htm -
The source file is in mkv format. How do i fix it to read in the new virtuadub 1.3?
Virtuadub 1.3 won't load my files. How do I either break apart the mkv format videos to recode the audio or recode them together?
mkvextract. you can also run multiple versions of virtualdub on the same system.
Read my blog here.
Still not working right. MVK extract breaks the audio into aac and I can't find a program to convert it to ac3 48000hz and some of the programs that i can find that can put it into like mp3 compress it from 21mins to about 13-15mins.
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 23:42 -
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 06:53 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 04:27 -
HD Mpeg2 Stream - playback/edit issues. Even VLC chokes
By bengance in forum DVB / IPTVReplies: 29Last Post: 2nd Nov 2007, 12:05 -
TMPGenc DVD Author 3 issues "No stream available" Error Code 0x80
By newsletters in forum Video ConversionReplies: 0Last Post: 8th Oct 2007, 18:20
