I know its older but it works (worked) for me. Anyway, I added 4 projects as chapters in my video. 2 chapters are just video+audio(from DV) & the other two are a JPEG slide show with an added MP3 audio track. WHEN PREVIEWING, MY PROJECT LOOKS EXCELLENT. However, when burning, I only get video on the 2 non-MP3 chapters with the 2 MP3 chapters being perfect. I tried changing the preferences from LPCM Audio to MPEG with 224 kps, both with same result. I checked the folders and there are no audio files after converting. I've already made 2 coasters. Any advice I've used Videostudio before- first time this happened.![]()
Try encoding the JPeg slide show + audio to MPeg2 before entering the "Create Disc" DVD menu. Then import the MPeg2 file from the "add video" button.
http://www.kiva.org/about -
Hi Ed,
1) shouldn't VS automatically encode the slideshow & video's to mpeg during the conversion stage?
2) the slideshow+audio project(chapter) authors perfectly to DVD. It's the DV video project(chapter) portion that has no audio.
Thanks -
Oh, I read it backwards.Originally Posted by g$$$money
You have found a bug.
It "should" do it but since it doesn't you can encode the DV chapters separately and import them into the DVD authoring as MPeg2.
help with Ulead videoStudio?
By wamit in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2009, 09:27 -
video capture problems in ulead videostudio 11
By scott114 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Jul 2008, 16:49 -
Audio not working in Ulead VideoStudio 8.0 SE DVD
By darts44 in forum AudioReplies: 9Last Post: 23rd Jul 2008, 08:54 -
Ulead VideoStudio 11 on Vista
By run1492 in forum Authoring (DVD)Replies: 2Last Post: 10th Jul 2007, 18:21 -
Audio problems with Ulead VideoStudio 8
By beanosirra in forum Newbie / General discussionsReplies: 4Last Post: 14th Jun 2007, 10:35
