I've downloaded and installed the latest ffmegx universal binary (v0.0.9x r2 9/28/06), downloaded the 3 ancillary binaries from the recommended urls, pointed ffmegx to the binaries and pressed Install. The popup says that the installation was not successful. I've attached a jpeg of the error message. Any suggestions as to what could be going wrong?
Better answered in our FFmpegX Forums. Moving you.
And welcome to our forums.
It seems you have put ffmpegX in a folder called "A/V Tools" or "A:V Tools". My guess is that the installer doesn't like the character between the 'A' and 'V'. Spaces in the path can also cause errors for some Unix style executables. Use a safe folder name like 'AV_Tools' or put ffmpegX directly in /Applications instead of a subfolder.
Major has advised putting ffmpegX directly into the Applications folder.
Add audio don't work on ffmpegX
By petwes in forum ffmpegX general discussionReplies: 1Last Post: 28th Jan 2012, 03:51 -
Will ffmpegX work in Snow Leopard?
By visitor13 in forum ffmpegX general discussionReplies: 5Last Post: 24th May 2010, 06:22 -
resume partial work done by ffmpegx somehow?
By jboyd in forum ffmpegX general discussionReplies: 2Last Post: 25th Jan 2008, 04:19 -
ffmpegX 0.0.9x r2 just won't work under X.3.9 ?
By Jose Hidalgo in forum ffmpegX general discussionReplies: 1Last Post: 16th Jul 2007, 08:37 -
Problem with iBook G3 after ffmpegx usage
By AndyPanda in forum ffmpegX general discussionReplies: 3Last Post: 25th Jun 2007, 16:46
