I am using TMPGEnc to convert AVI files approximately 40 minutes long to MPEG1 format.
The AVI files are between 220k to 350k depending on AVI format and quality.
A majority of the AVI files convert to an MPEG approximately 450MB that can be easily burnt to VCD (using Nero).
About 30% of the AVI files convert to an MPEG approximately 800MB to 850MB. These files do not fit properly on a single CD-R.
Is there anything I can do to shrink the large MPEG so they will fit on a single CD-R? Is there a setting in TMPGEnc that will encode a smaller MPEG?
Some
Are you using the VCD template that comes with TMPGENC? I f you are you should be able to get approximately 80 min of video on a vcd. As to the ones that convert to 800 to 850 MB I you play them I would think they would play for approximately 80 min if you used the vcd template with tmpgenc. Basically 1 min of video equals ~10MB in vcd mpeg format. You can lower the video bitrate setting or audio bitrate setting to produce a smaller mpeg file.
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
convert compressed avi files to mpeg without increase in file size?
By jasoothai in forum Authoring (VCD/SVCD)Replies: 7Last Post: 2nd Nov 2011, 05:29 -
Is there a max file size when Joining avi files.
By admjim in forum ffmpegX general discussionReplies: 2Last Post: 14th Feb 2010, 03:41 -
File Size Limit With TMPGEnc Plus 2.5 or MPEG-2?
By RABinMS in forum Video ConversionReplies: 5Last Post: 10th Feb 2008, 14:30 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50
