I donated to get the full version of SVCD2DVD. I needed a program that was an all-in-one solution for converting and authoring my HD captures (.ts files) onto DVD.
Initially, I had some success - SVCD2DVD converted my .ts files with good video quality and AC3 audio, and shrunk them down to fit on a DL-DVD. Unfortunately, this program's menu designer is seriously weak. No automatic thumbnail image capability, and you can't even add your own text - i.e. a title? - to the menu. After burning, the menu wouldn't work - either on my computer or stand-alone DVD player.
Frustrated, I decided to use my Nero 6 Ultra to burn the mpegs which SVCD2DVD had converted so that I could use Nero's menu designer. First, I dropped another 20 bucks to get the AC3 plug-in. Unfortunately, I then discovered that Nero views my 7.87GB of SVCD2DVD mpegs as being 9.28GB!
So now I'm right back where I started - I've got some awesome HD captures of an awesome football game, which I can't turn into an awesome DVD - except that now, I'm 60 bucks lighter.
Help would be appreciated, but I know you can't support Nero.
Well you can add thumbnails to a menu but first can you tell me why the menus don't work... Lets get to the bottom of that first.
trouble with SVCD2DVD menu selection highlighting
By bobarnett in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 4th Sep 2011, 14:59 -
SVCD2DVD Error when encoding menu??
By gsmb in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 23rd Feb 2011, 13:44 -
Really strange SVCD2DVD menu problem
By denali in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 4th Oct 2009, 11:41 -
HELP svcd2dvd output too big for a dvd
By scaffers in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 12th Nov 2008, 13:42 -
SVCD2DVD 2.5 Problems
By mistalcote in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 18th Aug 2007, 03:31
