Some of the movies only can be ripped by DVDFab Decrypter. So I rip one of them to a folder. I then burn it to Nero image drive, and got a nrg file. I use two different tools to make virtual DVD drive - Nero image drive as well as Daemon tool. I mount the nrg file to these virtual drives, and the movie play just fine.
When I try to use Ripit4me to get a menu+movie ftom the virtual drive, It/DVddecrypter error out with this :
Please help !!!
I'm sorry my suggestion didn't work for you. When I read what you had posted earlier, I had an iso I was about to delete, left over from a project I had just finished, and gave it a try. It worked with no hitches. I used Image tool to make the iso. Maybe something about the nrg file is incompatable(?). Again, sorry it was a misfire.
You did not misfire.
I double checked my setup, Ripit4me is using a older copy of DVDdecrypter. I un/reinstall the latest version of DVDdecrypter, now DVDdecrypter started to rip. I think nrg files, and both virtual drives should work now.
Thanks again. I wanted to to this for a while. You started me to ACTUALLY do it.
is it possible to create a virtual drive in RAM ?
By AlinaVastag84 in forum ComputerReplies: 18Last Post: 23rd May 2010, 11:53 -
DVDDecrypter work in Win XP Pro x64 w/ external drive?
By redsandvb in forum DVD RippingReplies: 8Last Post: 14th Jun 2009, 19:15 -
Can RipIt4Me rip the DVD folder in the hard drive?
By coody in forum DVD RippingReplies: 8Last Post: 13th Jun 2008, 13:01 -
ripit4me & rip aborted?
By Mort439 in forum DVD RippingReplies: 3Last Post: 25th Nov 2007, 10:13 -
How to use DVDDecrypter to "rip" from HDD files?
By sowhatu in forum DVD RippingReplies: 1Last Post: 13th May 2007, 10:19
