I'm new to this forum and hope someone can help me out. I am trying to convert mov. files with version 2.5. I keep getting a floating decimal point error early in the conversion. Never had this problem with my old 12a version. Unfortunately, I no longer have 12a and can't find it anywhere. Can anybody help?? Also, anybody know of any other .mov to .mpg converter?
Thanks, Hippie
I have found the same prob with some of the newer mov files(Iassume you are converting movie trailers?). They give a Floating decimal point error as soon as it begins converting....i cant figure out what the prob is. <aybe the QTreader plugin cant deal with some of the newer QT5 .mov specifications....Not sure...
You can found old TMPGEne version here:
http://www.granavenida.com/vcdspain/down/tmpgenc.htm -
That site doesn't seem to be working at the moment. Does anyone have a copy they could post on the net for a few days so that we can all download a copy?
Johncc35. Their homepage posted this on 9-28-01. "Since we have released updated version as 2.00, we stop developing version beta 12x any more, we recommend all users to switch to 2.00 from beta 12x unless you use older version with your own risk. We do not permit re-distribution of any version, especially version beta12x or older at any website."
Can someone post 12a somewhere? Please!!!!!!!!!!!
Hippie
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 08:57 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
