Apologies if this is dealt with elswhere, but due to the characters used in the search I keep getting nothing back (my searching probably).
When I record from Sky+ (via Copy) to my Philips DVDR3365 I've notice that the recording is made in 4:3 and not 16:9 widescreen (how it's taken me so long to notice I'll never know!). At first I thought it was setup, so I checked all of this, then I thought perhaps the particular program wasn't WS but I've checked this too.
Sky+ is set to 16:9 on both scarts (although I use only 1) and the DVDR is set to 16:9 to0o. In pasthrough mode (dvdr off) and on TV mode (dvdr on) the picture through from Sky is fine and in the correct ratio, so it seems to be only when recording.
Anyone seen anything similar and how can I stop this happening?
I found a little app IfoAR2WS.exe which will re-set the widescreen bit AFTER DVDshrinking to PC...but that means re-authoring everything instead of just recording it.
Any help gratefully received.
Yeah, but it still means copying form Sky then copying to PC and then copying back off PC...intsead of just having the widescreen bit set correctly?
recording SKY+HD
By snadge in forum DVB / IPTVReplies: 0Last Post: 26th Feb 2009, 13:15 -
Recording from Tata Sky
By planetx in forum Capturing and VCRReplies: 1Last Post: 7th Nov 2008, 22:07 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 18:46 -
Sky + And/Or Sky HD Recording To Pc With DAZZLE
By akenny01 in forum Capturing and VCRReplies: 0Last Post: 7th Mar 2008, 19:02 -
Sky+ recording to dvd help!
By dollydoodledumplin in forum Newbie / General discussionsReplies: 2Last Post: 24th Nov 2007, 01:25
