I have few questions about settings in WinDV
1. What mean option Discontinuity treshold.
2.Max avi size: What should to type that WinDV dont split my captures at 3.96 GB(i have NTFS partition)
3.What mean option every N-th frame?
And last what mean option numbering digits(2). What should stay 0,1,2,3,4
Just to mention i use windv for capturing analog material(VHS) with canopus 110 and cedocida dv codec.
thanks
Working backwards
You only need to set a higher number of digits if you have a small file size. It is to sequentially number the files as they split.
Every N th frame means just that. if you set it to 3, every third frame is transfered, and the rest are skipped. Leave it at one for normal transfer.
Set the max size to something stupidly big - 1000000000 or so.
Not sure what the discontinuity threshold is for, but most guides seem to recommend it be set to 0Read my blog here.
http://windv.mourek.cz
The screen shot is interactive and gives some help...
This is the minimum amount of time that the timecode between two clips can be different before a new file is created. When you record DV video, the time from the clock on the cam is also recorded (called "timecode"). An example:Originally Posted by SerbianBoss
1) Record some video, stopping at 13:20.
2) Record some more video, starting at 13:30 and stopping at 13:40.
3) WinDV can tell that there's different clips by the difference in the timecode. If the difference (in seconds) is more than what's defined in the Discontinuity threshold, a new file will be created.
My setting is 1.
However, as you're capturing from an analogue source I doubt this setting will make any difference. Set to 0 or 1 anyway.
Do your sums based on:Originally Posted by SerbianBoss
1) PAL = 25 frames per second or NTSC is (just about) 30 frames per second. I'll guess Serbia is PAL video format.
2) DV AVI is about 13.5Gb per hour.
I set my WinDV to 1,000,000 - this equates to around 11 hours. Much more than any DV tape can hold, and probably plenty enough for your analogue source.
This sets WinDV to capture "Every N-th frame" - 1 means capture every frame, 2 means every other frame, 3 means every third frame etc.Originally Posted by SerbianBoss
My setting is 1.
Whatever you like... If you have the filename as "wedding", the video files will be:Originally Posted by SerbianBoss
0: wedding.yy-mm.dd_hh-mm-ss.avi
1: wedding.yy-mm.dd_hh-mm-ss.N.avi where N starts at 0 and is 1 digit long
2: wedding.yy-mm.dd_hh-mm-ss.NN.avi where NN starts at 00 and is 2 digits long
3: wedding.yy-mm.dd_hh-mm-ss.NNN.avi where NNN starts at 000 and is 3 digits long
etc.
I hope that helps.
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
What about cassettes that doesnt have datecode, but timecode?
I see the timer resets sometimes, but it doesnt get split. Have tried several different types of software.
Confusing!
Well, VHS capturing Mostly cartoons, having some questions:)
By zerowalker in forum Capturing and VCRReplies: 943Last Post: 31st May 2013, 00:30 -
Three questions about capturing streaming video
By jimdagys in forum Capturing and VCRReplies: 2Last Post: 27th May 2011, 06:47 -
a few questions about capturing HDTV
By deadrats in forum Capturing and VCRReplies: 14Last Post: 26th Dec 2008, 09:39 -
Questions about capturing with component...
By Kisai in forum Newbie / General discussionsReplies: 14Last Post: 28th Apr 2008, 00:30 -
WinDV Capturing Problem
By ViperUKR in forum Capturing and VCRReplies: 12Last Post: 27th Jul 2007, 00:14
