I am trying to copy a home video on VHS to a DVD. I am using a 8X DVD+R. How do you tell if it is a RW? What kind of DVD'S should I buy? 8X 16X etc.?
First, the owners manual should tell you what speed disc to buy. Or you might try the Polaroid site:
http://www.polaroid.com/select_country.jsp;jsessionid=FpyLR3YlLG17nH2GTtGn 8nXJ4LZhdgK283v9GL7B3g6r2dGv4Jc9!-2124621506?PRODUCT%3C%3Eprd_id=845524441764403&FOL DER%3C%3Efolder_id=2534374302032643&bmUID=11638175 44115&bmLocale=en_US
Second, check this thread for information on media brands and speeds:
https://forum.videohelp.com/viewtopic.php?t=314198&highlight=
Third, the RW discs I've used all state "RW" on the case and disc. If your coumpter has DVD burning software you can use that software to check your discs. You can also use DVDInfoPro to check your discs for numerous things.
Good luck.
Polaroid DRM-2001G Hard Drive
By martye in forum DVD & Blu-ray RecordersReplies: 0Last Post: 28th Jun 2010, 08:56 -
Looking for a DVD recorder with hard drive
By sldvd in forum DVD & Blu-ray RecordersReplies: 2Last Post: 9th Jun 2009, 10:30 -
dvd recorder with hard drive?
By chuckliddell101101 in forum DVD & Blu-ray RecordersReplies: 31Last Post: 24th Jan 2009, 18:51 -
DVD Recorder hard drive upgrades
By pedmundson in forum DVD & Blu-ray RecordersReplies: 4Last Post: 5th Oct 2007, 14:16 -
DVD Recorder vs. Hard Drive
By docref in forum DVD & Blu-ray RecordersReplies: 9Last Post: 14th Aug 2007, 01:27
