Hi all
How to convert DVD with subtitles to VCD with rendered subtitles? I used DVDx but the video quality is more poor then from TMPGEnc and also subtitles looks very poor also.
How anybody is doing that?
Jan
Hi Condor! I just read your post and I got very interested on your commets. Unfortunately, I don't have any answer for you (since I'm just a "newbie" in this business). But I want to ask you some questios about your topic:
1) Is it possible to encode with subtitles using TMPGEnc?
2) How? (I mean, where can I get a guide to do this?).
Hope to hear from you soon.
Best regards,
Cesar Villanueva -
It is possible with Virtualdub as frameserver, I found a guide somewhere around here or doom9, stry searching and youŽll probobly find it.
And Condor, IŽve also tried DVDx and the subtitles was in very poor quality. Tried a lot of different setting but was never satisfied. It lokks way better with TMPGEnc -
Hi Jan,
if you want to add subtitles when using TMPGEnc, then you will have to frameserve through Virtualdub first. In Virtual Dub you can use the VobSub filter to add subtitles in the color you like.
The best guide(in my opinion) can be found on: http://www.flexion.org
have fun
The Dutchman -
Generally, there are two (perhaps three if you count DVDx but I don't like it) main methods for using subtitles:
One is to frameserve through Virtualdub to the encoder of your choice (usually TMPGEnc).
Second is to use FlaskMPEG and use a plug-in (or frameserve) -- the Panasonic MPEG Encoder plugin is highly recommended.
I personally prefer the FlaskMPEG option as it is simply a much more elegant process and you can preview the the subtitles BEFORE encoding (to make sure you've selected the correct one). If you do use FlaskMPEG for the purposes of subtitles, I strongly suggest you get FlaskMPEG v0.6 prev1.1 the subtitled fixed version (from doom9.net ).
Also, just about every method of subtitling is described in one of the guides on doom9.net
Regards.
Michael Tam
w: Morsels of Evidence
Probelm with DVDx 4.0
By vevdare in forum DVD RippingReplies: 0Last Post: 13th Dec 2011, 22:57 -
New DVDx 2.20 release is out!
By Jim@labDV.com in forum Latest Video NewsReplies: 3Last Post: 16th Jun 2009, 01:53 -
New DVDx InfoTool is out
By Jim@labDV.com in forum Latest Video NewsReplies: 0Last Post: 22nd Dec 2007, 08:32 -
Error in DVDx?
By php111 in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2007, 14:17 -
sync probs with dvdx
By zookeeper525 in forum AudioReplies: 0Last Post: 18th Aug 2007, 22:28
