  1. I am new to all this but having read lot's of posts here I have managed to get along pretty well but I still have a problem. I am trying to create a VCD of camcorder footage captured using a ATI all in wonder card. I am capturing in mpeg1 - video cd format and then using tmpgenc and finally using nero to burn. Everything seems to work fine but when I play the vcd on my DVD player the picture freezes briefly every 5 or 6 seconds. Can anyone help?
  2. Your DVD player might not be designed to read burned media. Usually those of Pioneer/Apex players play CD-R/RW pretty well.
    You might want to try several burning speed or try media of other dye color such as the black type. Someone even claims that Super-High quality CDRW should work. Not sure about this as I still cannot find any Super-High quality CDRW.
  3. Thanks for that.
    Can anyone suggest a make of cd-r/rw that is known to work with JVC dvd players?
    Cheers
  4. This site has very good listing of that:
    http://www.vcdhelp.com/dvdlist/listall.html
    Good Luck!
  5. Hi, i HAD the same problem...and the problem is that you are encoding the VCD at to high a bit-rate for your computer to handle....my Phillips cant handle over 2500 on VCD's...dont know why....but if i encode something at 2600..it wont work...and if i encode at 2400....it will...hipe this helps
