Hi,
How can i encode one big wmv file, 640x480 in size into several 320x240 4Mb smaller files?
thanks
Making the frame size smaller, doesn't make the file size smaller. They have to be reencoded at a lower bitrate. Try Windows Movie Maker.
/Mats -
first of all thanks for the fast reply.Originally Posted by mats.hogberg
well,
hmm... i already know that
too bad you didn't read the enrite post
i need a tool that can encode + change the frame size + make several small files from one file. several files...
thanks
edit:
if i have let say a 20Mb file it will reEncode it into a differant bitrate AND into five 4Mb files... -
This is no dvd to. Moving you.
Cut with windows movie maker and save as 4 files??? -
Yes, I read your whole post. And yes, the answer is still WMM.
/Mats
Should converting a mov file to wmv be so small?
By abrand88 in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2010, 14:47 -
H.264 output file size too big vs WMV
By bijoythulas in forum Video ConversionReplies: 5Last Post: 29th Sep 2008, 22:21 -
Can a QT file get as small as a WMV?
By Antoniola in forum MacReplies: 6Last Post: 22nd May 2008, 01:13 -
Trying to add a small intro clip to a movie file without re-encoding
By solar2504 in forum Video ConversionReplies: 11Last Post: 19th Mar 2008, 10:19 -
By solar2504 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 18th Mar 2008, 02:53
