I have a stack of tdk DVD-RW's (1-4X) that i use constantly. Problem is i've just changed pc and instead of the liteon i had previously, i now have a sony DW Q30A. It defaults to 4x burn rate. No problem i hear you say!! Well my home dvd player is a bit tempremental and will give jerky playback at this burn rate. Will play absolutely fine when burnt at 2x. And no, my player is not old its approx 6 months old and is a panasonic dvd/ram recorder.
I really want to avoid discarding a load of perfectly good discs.
How can i have the burn rate lowered? When ever a drop down menu comes up for burn speeds and i select a slower speed it seems to default to max rate for disc. Wondering if the drive was flashed before i purchased it?
Any ideas? Thanks.
Being thrifty is often a pain in the ass.
Google is your Friend
PRO slower ???
By cgp in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 12th Jan 2011, 10:49 -
Where did I go wrong: Better parts, slower PC
By beavereater in forum ComputerReplies: 17Last Post: 4th Dec 2009, 16:22 -
Burning speeds
By Rogert in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2008, 08:28 -
Burning at lower speeds lengthens the life or your burner?
By LittleQueenie in forum MediaReplies: 10Last Post: 25th Jun 2007, 19:40 -
Burning speeds and DVD Decrypter...
By Nilfennasion in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2007, 05:32
