    Feb 2005
    Bollywood
    Hi,
    I would like to pose a question about cropping. I am a lil confused on what aspect ratio to use for cropping DV footage to remove distorted overscan edges from a recorded broadcast.
    I use a Sony Digital 8 video camera to record movies cause we don't have a HD/DVD recorder yet!
    PAL DV footage is captured at 720x576 which has an aspect ratio of 5:4.
    But the broadcasted signal and target format is 4:3 standard size TV.
    If I want to crop the edges which aspect ratio do I use? 5:4 or 4:3?
    Currently, I am entering these crop values into ffmpegX: | top | bottom | left | right |
    | 12 | 12 | 14 | 16 |
    So the PAL DV footage that was 720 x 576 is now 690 x 552 which, after cropping the edges, then gets resized by ffmpegX's mpeg2 engine to DVD compliant size of 720 x 576.
    My crop values have the ratio of 5:4.
    Is this correct? Or should I be using 4:3 because the target viewing format is a 4:3 TV?
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    You cropped correctly. You crop with the same ratio as your source, then the cropped movie will scale correctly, maintaining the dimensions (width, height) of the objects on the footage.
