This may be a bit unusual so I hope someone can help me..
I had use of a Panasonic DVD recorder while staying with a friend out of town except I didn't "finalize" all the DVD I had started recording with the DVD recorder.
We had a video camera hooked up to it with footage and I desperately need access to it.
I thought of even shipping all my DVDs to him to finalize but he no longer has the machine.
So... i need to find a way to access these video files or finalize the DVD... or I guess i have to go and buy a panasonic DVD recorder... which will have to be a last resort-
is there ANYWAY to finalize the DVD or get access to the DVD contents?
thanks,
andy
Does Windows even read the disc? What do you see in Explorer?
XP
Intel Celeron D 335 Prescott 2.8GHz Socket 478 Pro
600GB
2G
ATI Radeon X1600 Pro
GIGABYTE GA-8I848P-G Socket 478 Intel 848P ATX Int
Lite-On DVD SOHD-16P9S
Hauppauge WINTV-PVR-150 PCI Interface Tuner Card -
Visit circuit city or best buy & use a panny at the store to do it. Why not? They are display models, so maybe they do it for you. I have a couple of pannys, they are pretty much the same so they should be able to do it.
I had the same problem with a customers dvd, her daughter who lives in Scotland sent her
the 2006 Military Tatoo on dvd but didnt finalize it. Her mother is here in Australia.
Anyways, the way i got the footage back was using ISOBUSTER and basically did a 'data recovery'
My ISOBUSTER was a trial version (1.9 i think.... and it wouldnt let me save the data
BUT... it created TEMP files which were about 1 gig (and had a NON-video file extension)
Just for laughs i opened one up with PowerDVD...and it was VIDEO/SOUND !!! yay
In closing, i had trouble reconverting the files back to dvd (tried Nero and Ulead no luck) in the
end i just played them trough PowerDVD and outputed Video/Sound to an external Dvd Recorder and problem solved.
Would been much easier if her daughter had finalized the disc
phil
Editing Panasonic Burner DVD-RAM VRO Video In Computer
By Teshia in forum User guidesReplies: 47Last Post: 18th Feb 2013, 09:06 -
DVD created with Panasonic DMR EZ 485v doesn't play back on computer
By gray9965 in forum Authoring (DVD)Replies: 2Last Post: 5th Jan 2010, 15:23 -
PANASONIC DMR-E50P I forgot to finalize years ago and now can't play DVD
By JWWILSONMD in forum Authoring (DVD)Replies: 2Last Post: 30th Sep 2009, 19:29 -
Panasonic EZ28k; correct aspect BEFORE finalize... NOT after.
By D'oh! in forum DVD & Blu-ray RecordersReplies: 2Last Post: 7th Feb 2009, 08:10 -
Mini Dv to either Computer or DVD - Panasonic NV-DS28
By Flowerpj in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 26Last Post: 26th Apr 2008, 20:31
