Hello all , I am in need of some help , I am tryinh to render a slideshow that i have compiled in vegas, as an avi . ( which ) I have done before. But i keep "freezing up after about 10-18 % ...
I thought i had this problem before , and i went in and increased the page file amount to the max. but i am still freezing .... what else could be doing this? I have plenty of hd space left , is there mabey any other preformance settings i should change .. I am pretty sure i have done slideshows longer than this before ..... what am i doing wrong..... Help Please ...
Ps i am not certain what else you might need to know , just ask
Results 1 to 9 of 9
Vegas freezes, or the whole PC stops dead ?
If it is the latter, try taking the case off and blowing a small desk fan through the PC while you render. If it succeeds, heat is your problem. Make sure there isn't a layer of dust on your CPU and other components, and consider better colling for your system.
FWIW, I didn't look at this sooner because of the post subject. "Vegas locking up when rendering" would have got my interest.Read my blog here.
I can't see anything here that indicates a page file problem.
A couple of things to try
1. Render to a different codec. You have plenty of options in a vanilla Vegas install, and you can always add other choices like Lagarith for lossless encoding.
2. Try rendering without audio
3. Try removing the stills that are around the 15-18% mark of your time line.Read my blog here.
ok, I will try deleting the pics near the freeze.. I must use the audio . thanks
ok , so removing the audio did not work , removing the stills in the area where it would seem to freeze didnt work) but this morning I decided to just try and render smaller peices of it , later putting them back together in anoother program and that worked at least sort of , it renders then i try to go in and do another section or two , and i am not sure but the next file will freeze ( i dont know the sizes i made these files ) .. but does this help anyone with my problem .. vegas used to work aso well for me , never freezing up ... help again
Try booting into safe mode, and then retry your project. If it goes farther, or doesn't hang up at all, the problem is with your system and/or resources available...
Rob
A good size of flash mp4 file on a page
By Cazz in forum Video Streaming DownloadingReplies: 5Last Post: 20th Dec 2009, 13:40 -
Page file set up PC
By santolina in forum ComputerReplies: 7Last Post: 9th Aug 2009, 14:52 -
The Summary tab on a Windows XP video file Properties page is missing!
By tigerb in forum Newbie / General discussionsReplies: 1Last Post: 18th Oct 2008, 22:11 -
Found useful program to defrag page file
By jimdagys in forum ComputerReplies: 2Last Post: 11th Oct 2008, 06:43 -
using a book page turning transition in vegas?
By Rudyard in forum EditingReplies: 1Last Post: 11th May 2007, 04:06
