Hi,
I have three movies which I am trying to encode to my ipod that I have decoded to a single vob (as described by the 640w guide). This method has worked great for me, aside from three movies, which result in a good movie output, but it has no audio.
I've noticed before that when encoding with ffmpegx that it lists the audio streams along with the video streams, but it does not with these three (all animated: Cars, Madagascar, The Incredibles) ... am I missing something here?
I've tried changing the audio track setting, and nothing seems to work. I've tried decoding with quicktime and not (it is *much* more reliable for me to deselect that when first encoding; leaving it on usually results in a movie thats ~100M or so) ... any help would be appreciated![]()
As I understand it, encoding to iPod H264 requires QuickTime to do the decoding. Unless QuickTime Player can play the source file perfectly, the underlying QT architecture will be unable to do the decoding when called by ffmpegX.
I always run every video I intend to transcode to iPod H264 through QT Player first. If it has trouble, I know ffmpegX will also have trouble. This is why the intermediate transcode is often necessary.
Don't forget about DivX Doctor II as a good tool to "doctor" AVIs that have goofy, compressed audio. You'll end up with a new .mov file that, while considerably larger, may be dropped into ffmpegX for the iPod H264 transcoding directly.
Let us know how it goes.
Some trouble with H264 compression
By Zhuge Liang in forum Video ConversionReplies: 6Last Post: 29th Jun 2010, 22:01 -
Trouble converting VOB to AVI using Handbrake (audio issue)
By binvisions in forum Video ConversionReplies: 1Last Post: 1st Aug 2009, 03:28 -
VOB to H264 MKV (AVI Synth and audio delay help)
By PsyCLown in forum Video ConversionReplies: 1Last Post: 20th Feb 2009, 01:52 -
h264 (MP4) to XviD (AVI) Conversion Trouble
By m93 in forum Video ConversionReplies: 5Last Post: 12th Dec 2008, 10:21 -
H264: Are there other h264 (AVCHD/VC-1) encoding command-line/CLI tools ??
By vhelp in forum Newbie / General discussionsReplies: 12Last Post: 16th Feb 2008, 01:20
