Ok, basically I'm wanting to go from my source Xvid..avi,with 23.976 framerate to compliant ntsc dvd. I know I have to change the framerate but i'm kinda stuck on the process. Should I use dgpulldown before doing my encode with cce or...encoded with cce with the source specs and then use dgpulldown afterwards...Any help would be much appreciated and if I haven't given enough info then feel free to ask for more.![]()
DGPulldown works on MPEG files, so you would use that after encoding your AVI to MPEG.
But CCE can do pulldown itself while making the encode.
There seems to be an option on the screenshot there anyway. -
CCE's pulldown works perfectly well. Encode as 23.976 with 2:3 pulldown in CCE and you won't need DGPulldown at all. If you were converting to PAL it would be a different story.
Read my blog here.
Thanx i'll try it out. I do see the 2:3 option but there is also a 3:2 option as well, whats the diffrence.
I'll give it a try tonight gunslinger, you have been most helpful, one last question,lol. Will I have to do anything with the audio? As far as problems with sync.
Trouble with DGPulldown
By ShitizenGayne in forum Video ConversionReplies: 5Last Post: 19th Nov 2010, 06:34 -
DGPulldown
By Airr in forum MacReplies: 6Last Post: 3rd Feb 2010, 11:38 -
DGPulldown Help
By Maikeru-sama in forum Video ConversionReplies: 13Last Post: 17th Sep 2008, 21:06 -
DGPulldown Question
By Maikeru-sama in forum Video ConversionReplies: 2Last Post: 19th Jun 2008, 17:46 -
DGPulldown and running time?
By ecc in forum Video ConversionReplies: 1Last Post: 19th Dec 2007, 04:23
