Results 1 to 17 of 17
    Oct 2006
    Greece
    I use CCE to encode and DVD-Lab to author.
    Now I got a new graphics card and a new processor (Intel Dual Core E6400 2.13GHz).
    Is there anything better I can do for encoding or I shall I keep using the same tools I used on my old CPU?
    New CPU didnt make DVD-Lab compiling faster... Is this normal?
    Thanks.
    Jun 2005
    Portugal
    Use CCE with AVISynth, and tune up your script using MT (MultiThreading in avisynth)
    Start your script with :
    SetMTMode(2)
    But you need the correct AVISYNTH version
    Oct 2006
    Greece
    I use AVIsynth 2.56. Is this the correct version?
    Here's the script I mostly use:
    # -= AviSynth v2.5.7.0 script by FitCD v1.2.8 =-
    AVISource("C:\test4.avi", audio=false)
    LanczosResize(720,480,20,0,600,272)
    AddBorders(0,48,0,48)
    #Trim(0,134721).FadeOut(150)
    ConvertToYUY2() # For VirtualDub or CCE
    So I just add "SetMTMode(2)" at the top?
    Does this affect quality in any case? Is there any site that I can read what exaclty happens with this line and why this can be used with 64bit processors?
    Jun 2005
    Portugal
    It speeds up CCE about 20% or 30%, it uses 100% CPU without hangups. Doesn't affect quality, only speed
    That's the advantage of having Dual Core CPUs, because you can run applications multithreaded
    Google for :
    SetMTMode MT
    And you will find it, or go to Doom9 ( CCE section )
    Oct 2006
    Greece
    really helpfull!
    THANKS!
    Dec 2004
    Australia
    As for the 64bit processor. Sounds like you are still running 32bit windows. Besides is there even a 64bit version of CCE? Squid_80 did some work on porting AVISynth, but a lot of things are still missing or are slower.
    Oct 2006
    Greece
    SetMTMode(2) does not work for me. CCE wont accept scripts using this line on top.
    I have AVIsynth 2.56...
    what can be wrong?
  8. I think you need version 2.6. Or maybe this:
    http://forum.doom9.org/showthread.php?t=94996
    Jun 2005
    Portugal
    Get MT
    http://www.avisynth.org/tsp/MT_05.zip
    And copy AVISYNTH.DLL to your System32
    DLL included in ZIP file
    Oct 2006
    Greece
    oops. stupid me. thanks!
  11. MT("Telecide(Order=1,Guide=1).Decimate(5)",2,2)
    works 60% slower than
    Certainly no 100% CPU utilization.
    In normal mode first CPU is 80%, second is 50% wich averages to 65%.
    In MT mode the first CPU is some 20% utilized, the second is 90%.
    Cann't tell it's possible don't tell anything.
    Jun 2005
    Portugal
    making frame serving multithreaded is usually enough
    That modified AVISYNTH and MT does a good job, but only running CCE standalone....well... all depends upon processes priorities
    that beginning line, for me is enough...in my humble opinion
    Oct 2006
    Greece
    Originally Posted by Delta2
    Get MT
    This zip contains MT.dll too. i dont use this at all?
  14. Originally Posted by nick_gr
    Get MT
    Copy MT.DLL to your AVISynth Plugins folder if you want to use the MT filter. If you are only going to use SetMTMode(2) you don't need the MT filter.
    Oct 2006
    Greece
    great! thanks.
    Oct 2006
    Greece
    I copied avisynth.dll to system32 and added "SetMTMode(2)" in my script, but made no difference.
    It takes me 50-55 mins to encode (3-pass) a 42min movie. With or without "SetMTMode(2)"...
    Do I do anything wrong?
  17. Originally Posted by nick_gr
    No, you didn't do anything wrong. It doesn't always decrease the overall processing time. So far the only filter I've found where it made a big difference was DeBlock(). I've only tried a handful though.
