I am trying to rip a dvd using dvd decrypter and once it gets to VTS_01_1.vob the read rate goes down to 0.0 and eventually times out... what could be the problem.. here is the Log
I 18:40:32 DVD Decrypter Version 3.5.4.0 started!
I 18:40:32 Microsoft Windows XP Home Edition (5.1, Build 2600 : Service Pack 2)
W 18:40:32 Drive D:\ (FAT32) does not support single files > 4 GB
I 18:40:33 Initialising SPTI...
I 18:40:33 Searching for SCSI / ATAPI devices...
I 18:40:33 Found 1 DVD-ROM and 1 DVD±RW!
W 18:40:38 Possible Structure Protection Found!
W 18:40:38 1 area has been marked as 'suspect'.
W 18:40:38 Dummy sectors will be inserted where necessary.
W 18:40:39 Possible RCE Protection Found!
W 18:40:39 Media region code: 1
W 18:40:51 User selected Region 1 for the disc's region code.
W 18:41:03 Possible Structure Protection Found!
W 18:41:03 1 area has been marked as 'suspect'.
W 18:41:03 Dummy sectors will be inserted where necessary.
W 18:41:03 Possible RCE Protection Found!
W 18:41:03 Media region code: 1
W 18:41:04 User selected Region 1 for the disc's region code.
I 18:41:13 Operation Started!
I 18:41:13 Source Device: [3:0:0] TSSTcorp CD/DVDW TS-H552D GA01 (E(ATA)
I 18:41:13 Source Media Type: DVD-ROM
I 18:41:13 Source Media Region Code: 1
I 18:41:13 Source Media Copyright Protection System Type: CSS/CPPM
I 18:41:13 Source Media Implementation Identifier: DVDAfterEdit
I 18:41:13 Destination Folder: C:\Documents and Settings\Owner\Desktop\DVD RIPS\
I 18:41:13 File Splitting: By File
I 18:41:13 Remove Structure Protection: Yes
I 18:41:13 Bad Sector Removal Method: Normal
I 18:41:13 Detect Mastering Errors: No
I 18:41:13 Multi Angle Processing: No
I 18:41:13 Remove Macrovision Protection: Yes
I 18:41:13 Stream Processing: No
I 18:41:16 Copying VIDEO_TS.IFO... (LBA: 451 - 476) - KEY: N/A
I 18:41:17 Copying VIDEO_TS.VOB... (LBA: 477 - 533) - KEY: N/A
I 18:41:17 Copying VIDEO_TS.BUP... (LBA: 534 - 559) - KEY: N/A
I 18:41:17 Copying VTS_01_0.IFO... (LBA: 75808 - 75878) - KEY: N/A
I 18:41:17 Decrypting VTS_01_0.VOB... (LBA: 75879 - 400127) - KEY: CB 21 C3 F4 48
I 18:43:07 Decrypting VTS_01_1.VOB... (LBA: 400128 - 924414) - KEY: CB 21 C3 F4 48
I 18:44:15 Skip Request Acknowledged
E 18:44:16 Failed to read Sector 409442 - Timeout on Logical Unit
E 18:44:16 Failed to decrypt VTS_01_1.VOB!
I 18:44:20 Decrypting VTS_01_2.VOB... (LBA: 924415 - 1448701) - KEY: CB 21 C3 F4 48
I 18:46:13 Decrypting VTS_01_3.VOB... (LBA: 1448702 - 1972988) - KEY: CB 21 C3 F4 48
I 18:47:52 Decrypting VTS_01_4.VOB... (LBA: 1972989 - 2497275) - KEY: CB 21 C3 F4 48
Update: I Just tried another dvd and this is the exact error I get on Both
I/O Error!
Device: [3:0:0} TSSTcorp CD/DVDW TS-H552D GA01 (E
(ATA)
ScsiStatus: 0x02
Interpretation: Check Condition
CDB: 28 00 00 01 41 D7 00 00 01 00
Interpretation Read (10) - Sector 82391
Sense Area: 70 00 04 00 00 00 00 0A 00 00 00 00 3E 02 00 00 00 00
Interpretation: Timeout on Logical Unit
The three movies I was trying to backup were
CLICK (gave me this error)
Poseidon (No errors ripped successfully)
The Break-up (gave me this error)
This is the log from The Break-Up
I 19:26:17 DVD Decrypter Version 3.5.4.0 started!
I 19:26:17 Microsoft Windows XP Home Edition (5.1, Build 2600 : Service Pack 2)
W 19:26:17 Drive D:\ (FAT32) does not support single files > 4 GB
I 19:26:17 Initialising SPTI...
I 19:26:17 Searching for SCSI / ATAPI devices...
I 19:26:17 Found 1 DVD-ROM and 1 DVD±RW!
W 19:26:20 Possible Structure Protection Found!
W 19:26:20 1 area has been marked as 'suspect'.
W 19:26:20 Dummy sectors will be inserted where necessary.
I 19:26:41 Operation Started!
I 19:26:41 Source Device: [3:0:0] TSSTcorp CD/DVDW TS-H552D GA01 (E
(ATA)
I 19:26:42 Source Media Type: DVD-ROM
I 19:26:42 Source Media Region Code: 1
I 19:26:42 Source Media Copyright Protection System Type: CSS/CPPM
I 19:26:42 Source Media Application Identifier: GEAR UDF Application
I 19:26:42 Source Media Implementation Identifier: GEAR UDF
I 19:26:42 Destination Folder: C:\Documents and Settings\Owner\Desktop\DVD RIPS\The Breakup\
I 19:26:42 File Splitting: By File
I 19:26:42 Remove Structure Protection: Yes
I 19:26:42 Bad Sector Removal Method: Normal
I 19:26:42 Detect Mastering Errors: No
I 19:26:42 Multi Angle Processing: No
I 19:26:42 Remove Macrovision Protection: Yes
I 19:26:42 Stream Processing: No
I 19:26:42 Copying VIDEO_TS.IFO... (LBA: 717 - 730) - KEY: N/A
I 19:26:42 Copying VIDEO_TS.VOB... (LBA: 731 - 1576) - KEY: N/A
I 19:26:42 Copying VIDEO_TS.BUP... (LBA: 1577 - 1590) - KEY: N/A
I 19:26:42 Copying VTS_01_0.IFO... (LBA: 1591 - 1646) - KEY: N/A
I 19:26:43 Decrypting VTS_01_0.VOB... (LBA: 1647 - 81706) - KEY: C0 36 82 A6 9C
I 19:27:15 Decrypting VTS_01_1.VOB... (LBA: 81707 - 605993) - KEY: C0 36 82 A6 9C
W 19:27:28 Inserting Dummy Sectors... (LBA: 81867 - 82218)
I 19:27:28 Extracting Sectors...
W 19:27:28 Sector 82327 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82328 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82329 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82330 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82331 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82332 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82333 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82334 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82335 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82336 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82337 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82338 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82339 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82340 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82341 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82342 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82343 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82344 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82345 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82346 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82347 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82348 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82349 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82350 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82351 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82352 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82353 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82354 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82355 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82356 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82357 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82358 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82359 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82360 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82361 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82362 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82363 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82364 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82365 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82366 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82367 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82368 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82369 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82370 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82371 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82372 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82373 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82374 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82375 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82376 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82377 - Pack Header Not Found (0x00000000)
W 19:27:28 Sector 82378 - Pack Header Not Found (0x00000000)
W 19:27:35 Sector 82379 - Pack Header Not Found (0x00000000)
W 19:27:35 Sector 82380 - Pack Header Not Found (0x00000000)
W 19:27:35 Sector 82381 - Pack Header Not Found (0x00000000)
W 19:27:35 Sector 82382 - Pack Header Not Found (0x00000000)
W 19:27:35 Sector 82383 - Pack Header Not Found (0x00000000)
W 19:27:35 Sector 82384 - Pack Header Not Found (0x00000000)
W 19:27:35 Sector 82385 - Pack Header Not Found (0x00000000)
W 19:27:35 Sector 82386 - Pack Header Not Found (0x00000000)
W 19:27:35 Sector 82387 - Pack Header Not Found (0x00000000)
W 19:27:35 Sector 82388 - Pack Header Not Found (0x00000000)
W 19:27:35 Sector 82389 - Pack Header Not Found (0x00000000)
W 19:27:35 Sector 82390 - Pack Header Not Found (0x00000000)
W 19:35:07 Failed to read Sector 82391 - Timeout on Logical Unit -
Ummm... those are all pretty new movies (except poseidon which is why decrypter prob. ripped it) with the latest copy protection on them...Originally Posted by fazeshot
DVD Decrypter is pretty old now and has not been updated in a looooong time and cannot defeat the newer protections.
DVDFab Decrypter -
use Ripit4me which has built into it Dvd Decrypter and you can open up Dvd Shrink from it as well. Download FixVTS as well which will open up with Ripit4me.
Help Ripping DVD by Chapter with DVD Decrypter
By lukebrowning in forum DVD RippingReplies: 3Last Post: 11th Jan 2011, 01:04 -
Trouble ripping The Ugly Truth with DVD Fab HD Decrypter
By heyjjjaded in forum DVD RippingReplies: 1Last Post: 22nd Dec 2009, 15:29 -
Any Free Alternative To DVD Decrypter For Ripping To Single VOB?
By DarrellS in forum DVD RippingReplies: 9Last Post: 11th Feb 2009, 01:41 -
DVD Decrypter / DVD Fab - Extremely slow ripping speeds in Vista
By awp in forum DVD RippingReplies: 5Last Post: 19th Dec 2007, 14:11 -
Problem burning to Verbatim DVD+R DL with DVD Decrypter
By spyder67 in forum Authoring (DVD)Replies: 6Last Post: 14th May 2007, 18:49
