I have a little problem with ImgBurn. If I burn say 5 divX files to DVD, 01 02 03 04 05, when they burn they always show up on DVD as 02 03 04 05 01.
Whichever way I rename or renumber the first file always ends up as the last.
Any ideas?
It isn't a imgburn problem. It is the way windows handles files.
If you select 5 files numbered from 1 to 5 and copy them somewhere they will copy in this order, 2, 3, 4, 5, 1
If you highlight files 2 to 5 and then hold down the ctrl key and select file 1 then copy they will copy as 1, 2, 3, 4, 5
ImgBurn
By didikai in forum Newbie / General discussionsReplies: 10Last Post: 17th Apr 2012, 23:18 -
Nero vs ImgBurn: Why is ImgBurn preferred?
By usually_quiet in forum Authoring (DVD)Replies: 31Last Post: 28th Aug 2010, 18:47 -
How do i use IMGBURN?
By mrjust in forum Newbie / General discussionsReplies: 6Last Post: 10th Apr 2009, 14:35 -
ImgBurn
By gomer in forum Newbie / General discussionsReplies: 2Last Post: 10th Mar 2009, 00:35 -
Upgraded to ImgBurn 2.2 - Now "ImgBurn Shell Ext" No Longer Works
By Cool Breeze in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 11th May 2007, 11:05
