I have some mov files I would like to join and convert to be able to play them at my TV. However I canīt get them to work proper. After I have joined and convert them, the sound get out of sync.
If I join the smal mov clips to one big mov file the sound is ok, but as soon as I have converted the joined mov file, it get out of sync. Have tried converting with both divx and xvid codecs and with different program such as Quick video joiner and TMPGEnc, but the result always get out of sync.
Have also tried to first convert the mov files to xvid/divx files and then join them with Easy video joiner/ AVI joiner, but with the same result, out of sync.
What cause these out of sync problems and is there away to get the mov files joined to one xvid file without loosing sync?
Convert each to divx/xvid with mp3 CBR audio(no vbr).
Join them with virtualdubmod instead of easy video joiner. -
Originally Posted by Baldrick
Where can i found mp3 CBR codec? I donīt have that codec to choose from. I use to use either Windows Media Audio V2 or MPEG Layer-3.
How do I join files with VirtualDubMod? -
Mpeg layer3 is mp3.
virtualdubmod or virtualdub or virtualdub-mpeg2,
file->open file
file->append segment
video->direct stream copy
file->save as avi
How to join mov files?
By Espen in forum EditingReplies: 61Last Post: 27th Sep 2012, 17:00 -
Split/Trim/Join MOV files (works great with Canon SX130's files)
By truchopol in forum EditingReplies: 3Last Post: 27th Jul 2012, 11:35 -
Join mov files and upload to youtube
By neelapala in forum EditingReplies: 2Last Post: 23rd Dec 2008, 12:09 -
MPEG4/AC3 videos saved as Self-Contained MOV files are out of sync
By cooperaa in forum MacReplies: 3Last Post: 5th Dec 2008, 03:52 -
PHP code used to generate code for Avysinth join mov and avi files
By lindylex in forum User guidesReplies: 0Last Post: 19th Sep 2008, 04:37
