Results 1 to 10 of 10
    Jul 2006
    Greece
    Hi!I have downloaded GSpot26 but I can't really understand how to use it.I have some files that-when converted to DVD- go out of sync.Please help!
    Apr 2004
    Miskatonic U
    g-spot is used to tell you what codecs were used to encode the video and audio. It doesn't actually repair video.
    Read my blog here.
    USA
    If you have AVI files, typically Xvids or similar downloaded from the net, they may have MP3 VBR audio. Gspot is one way to see if this is a fact. Look to the little green window on the right side of the Audio area. If 'VBR' is lit, then it could be the problem. It commonly causes sync problems when you convert the video to MPEG-2 to burn to DVD. AC3 audio can occasionally cause this also.
    If this is the problem, you can save out the audio as a WAV with a program like VirtualDub Mod, then process it separately before joining it back with the video when you author your video to DVD format.
    Jul 2006
    Greece
    I do not see a green window on the right side of the Audio area.VBR is not lit. :( Am I doing something wrong?
    The info I can see is Path,Size and under Container
    File Type: ASF (.WMA/.WMV)
    Mime Type: video/x-ms-asf
    The problem is that this info appears on two different files:when converted to dvd,one of them is OK,but the other is out of sync.Does this make any sense?And what is the problem?
    Jul 2006
    Greece
    Could someone pleeeease help me?
  6. Originally Posted by aaaaa
    I do not see a green window on the right side of the Audio area.VBR is not lit. Am I doing something wrong?
    That's the problem. It's a WMV file, not an AVI. GSpot won't give you much information at all about WMV files as you've already seen.
    I had a WMV file that I wanted to convert, and just about anything that I tried, I could not get the audio and video to sync when I converted it. I tried Super, I tried writing an AVISynth script and running it through VirtualDubMod, I tried using Windows Movie Maker (which just crashed on me.) I finally found an easy way to do it. I used Nerovision Express 4 and made a DVD from the file that way.
    Most people here will frown upon Nerovision, and I don't use it much for anything, but it did the trick for me this time.
  7. Mod Neophyte redwudz's Avatar
    USA
    Nerovision would probably work as good as another program. I would try SUPER first, though. I suspect the ASF video could still have VBR audio, along with VBR video. Makes it very hard to convert without sync problems. Throw in DRM encryption and it's hardly worth the effort. The problem with VBR audio is that most MPEG encoders can't measure or 'see' the length of the audio. So they make it some odd length when they re-encode it, at least not the same length as the video, and then you have a sync problem.
    Jul 2006
    Greece
    I so not have Nerovision Express 4,I have Nerovision Express 3 but it doesn't work.
    "That's the problem. It's a WMV file, not an AVI"
    Ok,but why does only one file of this type work?If that is the problem,shouldn't BOTH files(same type) be out of sync?
  9. Member MysticE's Avatar
    Nov 2003
    If you were to peruse these forums you would see that are very few constants per se. If in fact these were both created at the same time with identical settings and software maybe.
    Try the free trial of ConvertXtoDVD and see what it does.
  10. Member Cornucopia's Avatar
    It didn't work for LloydAZ, but maybe it will for you:
    Open in WindowsMovieMaker(2)--but don't let it "make clips" based on I-frames, which is a waste of time here.
    Drag to timeline (audio+video), Don't edit, just export:
    Use File | "SaveMovieFile" | MyComputer | ... | ... | Other settings --> DV-AVI (PAL)
    This will be a type1 DV-AVI file (which is hard for lots of apps to use), so you may need to change it into a type2 DV-AVI file with the freeware DVDate. Then you shouldn't have any problem with it.
    From there, open in your usual apps and convert to MPEG2/DVD and enjoy!
    Hopefully, you won't have any sync problems this way...
    HTH,
