Hi,
Apologies if this has been answered somewhere else but I've done a pretty exhaustive search and had no luck (got stuck on key search words really). I recently bought a new DVD writer to go with my new rig (it's a Samsung, not sure of the model) and got some new media along with it. Now I know the drive is working fine as I have since backed up a lot of things to several (TDK) DVD-RWs 4x with no probs. However, I also have some DVD-Rs 8x 4.7GB and when I insert any one of them, the program reports nowhere near 4.7GB (or 4.37GB) available, more like 1.4GB. I use Nero for the majority of my burning but I've also tried ImgBurn to burn an ISO directly and it reports there's not enough room. The DVD-Rs are Tescos own which I would suspect are lesser quality (Tescos is a supermarket - not sure if this is a UK site). Is this a simple setting (of format or something) or is there something wrong with the actualy discs??
Any help, much appreciated.
Mike
Probably the discs, my missus needed some CD-Rs in a hurry and bought some of the Tesco own brand ones. Even they failed! Try some decent discs and see what they are reported as. Bear in mind though that you can't always go by the brand name on the pack, some well known makes can still be pretty poor (although not as bad as the Tesco own brand ones). If you are in a hurry, see what your loacl PC World has in stock (they usually stock Verbatim which are worth trying) or, better still, order some from www.svp.co.uk. Then you really will know what you are buying.
Low File Size yet retains the original quality. How?
By NeroLi8gerzid in forum Video ConversionReplies: 8Last Post: 6th Oct 2011, 17:46 -
What do you think??? Maximum Quality/Low File Size DVD conversion
By iqbal88 in forum DVD RippingReplies: 6Last Post: 7th Aug 2011, 02:48 -
Auto-GK file output, low quality despite large size
By Fallout1 in forum Newbie / General discussionsReplies: 10Last Post: 5th Oct 2009, 18:27 -
converting down to low size yet maintain good quality
By lawlbear in forum Video ConversionReplies: 3Last Post: 19th Dec 2008, 18:06 -
Low size, high quality WMV files
By devilfruit in forum Video ConversionReplies: 2Last Post: 29th Jan 2008, 17:08
