Hello,
I have a bin file on my pc which I would like to burn to a dvd. Is it possible using the Nero 7 reloaded software?
I have read several posts on here regarding this topic but couldnt find a definitive answer. I know it is possible to burn to a CD but would prefer it on DVD. Perhaps there is a way to convert the files first?
Thanks for any help.
You likely have a bin/cue image created from a physical CD, then you can't burn it to DVD directly but you can first extract the files from it using e.g. UltraISO (if you have a data CD image). What was the type of your CD (data, audio etc.) represented by image files?
Read this: https://forum.videohelp.com/viewtopic.php?t=233348
Extract the video, tell us what it is (you can check with Gspot), we can advise how to put it on DVD."Art is making something out of nothing and selling it." - Frank Zappa
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 21:33 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 12:58 -
Opening .bin file jpg
By chewie8008 in forum ComputerReplies: 4Last Post: 18th Jul 2007, 17:01 -
Bin file
By anton225 in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 14:05 -
how to burn a BIN File
By Chris 67 in forum Newbie / General discussionsReplies: 4Last Post: 28th May 2007, 08:44
