Ive updated my ffmpegX to the 0.0.9x version
I downloaded the three components and added them to the ffmpegX folder in applications including the mpeg2enc.intel file which for somereason has a Excel icon
I then opened ffm and it asked where the three compoments were and I directed it.
it seems that each time I open it it asks for the directions to mencoder and mplayer which haven't moved from that ff folder I made in apps
however on opening ffm and adding my pesky .ts file (h264) this newwer version acutally does something but not much. the older ffmpegX frin sept 2005 did nothing but think about it for ever.
this one is lighting fast but I don't think did anything and I got this message after looking around:
dyld: Library not loaded: /usr/local/lib/libvorbis.0.dylib
Referenced from: /Library/Application Support/ffmpegX/mencoder
Reason: image not found
Encoding started on Wed Nov 15 12:53:18 EST 2006
any ideas on whats next? Doom?
MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
QTPro, MPEG2 add on MPlayerX2
MPEG Streamclip
24 + 21" samsung flat panels
G4dual 2GB
AlchemyDVR card -
The downloaded binaries can reside on your desktop until the Components Self-Installer copies them to their special place. After that, you may delete the downloaded files. The installer also makes mpeg2enc a Unix executable when copying, so the icon is unimportant.Originally Posted by rotuts
On launching ffmpegX, it checks the version/filesize of the binaries in /Library/Application Support/ffmpegX/. If they are not right or not there, the app will ask for them again. Try downloading mencoder/mplayer again. The zip archive should be 14.4 MB (15119081 bytes), with mencoder 16655780 bytes and mplayer 15869784 bytes. Remember to log in as Administrator when installing.Originally Posted by rotuts
No idea on your error message, tho'.
FFMpegX Audio problems
By Cowchan in forum Newbie / General discussionsReplies: 0Last Post: 11th Dec 2011, 10:00 -
ffmpegx problems with RM to AVI
By mgarman14 in forum ffmpegX general discussionReplies: 13Last Post: 2nd Sep 2008, 12:45 -
ffmpegX Installation problems....
By maiof06 in forum ffmpegX general discussionReplies: 1Last Post: 31st Aug 2008, 01:32 -
Problems with ffmpegX
By KeepItSimple in forum MacReplies: 2Last Post: 5th Apr 2008, 20:46 -
ffmpegx Problems! Help!
By The Sumerian in forum ffmpegX general discussionReplies: 4Last Post: 10th May 2007, 00:36
