hi. been trying to download and intstall the x264 codec but end up with a end up with a x264qtcodec-1[1].0.0.dmg file that dosent do anything on my computer!!
does the x264 file work with windows xp??
where can i download and install this codec??
ta ta
He's a liar and a murderer, and I say that with all due respect.
Actually, what you're looking for is the H.264 codec. x264 (at least on the PC end) is a command-line only encoder now, if I remember correctly. Not sure what you can use in a general codec sense (decoder AND encoder), but the Tools section in the menu to the left is a good place to start. Search for "H.264" or "H264" (without the quotes, of course).
Incidentally, .dmg files are usually Mac disk images.If cameras add ten pounds, why would people want to eat them? -
There is no x264 codec. It is an encoder only, no decoder and the command line (only official encoder since VfW support was removed) is still H.264.
"264qtcodec-1[1].0.0.dmg" would be for OSX. No port for quicktime under win32 as far as I know. Doesn't make too much sense anyway since it would mean that you could encode streams with QuickTime that it itself can't decode do to the crappy AVC decoder that ships with QuickTime.
Probably you want the VfW encoder, which was removed from offical source. You can still find binaries at Death The Sheep's site though. -
If you need a VFW x264 encoder the last (as far as I know) version with the VFW encoder can be found here:
http://mirror02.x264.nl/x264/revision573/x264-573-install.exe
As celtic_druid is so fond of pointing out, x264 only includes an encoder, so you'll need a decoder to watch your creations. You can use ffdshow or a media player with an h.264 decoder built in -- like VLC.
Other x264 resources:
http://developers.videolan.org/x264.html -
Actually there is a revision 600 (current revision) build at DeatTheSheep's site. They also I believe added some of the missing features.
I'm not posting a link, but anyone who really wants to encode via VfW, just search for "DeathTheSheep United AVC VfW".
x264 codec decoding limitations
By Medieval1233 in forum Portable VideoReplies: 2Last Post: 30th Dec 2011, 18:54 -
How to make x264 codec do 16:9?
By brassplyer in forum Video ConversionReplies: 3Last Post: 27th Oct 2011, 18:17 -
I want use x264 codec in virtualdub but i can't
By Hugo12317 in forum Video ConversionReplies: 5Last Post: 6th Jun 2011, 14:41 -
I can't figure out how to use the h.264 (x264) codec!
By Tahlos in forum Newbie / General discussionsReplies: 9Last Post: 15th Jun 2010, 19:34 -
VirtualDub doesn't see x264 codec.
By olegk in forum Video ConversionReplies: 7Last Post: 9th Jun 2010, 03:10
